6.0 at 30 below
Old Jan 7, 2004 | 05:16 PM
AlaskaPowerStroke's Avatar
AlaskaPowerStroke
6.0 at 30 below
Thought we would let you all know how our '03 6.0L is doing with the Alaska temperatures. We plug in at 10 to 20 above or colder, though it has started at -20 with only 30 minutes plug-in time (not reccommended). We have cold fronts in the grill and block heater, oil pan heater and battery heaters(used occasionally - will probably switch to trickle chargers).
The truck runs well once warmed up - a little more noise than usual until then. As with anything at -30, the clutch is a bit sluggish as well as the brake pedal. We have found that ABS does not do well below -20 and we typically apply the brakes a bit when going down the road to loosen them up. We have driven it at -48 and it got us where we wanted to go.
18,000 miles and counting.
There are a lot of new Fords here in the Fairbanks/North Pole area. Good sign.
Old Jan 7, 2004 | 05:21 PM
emtabmm's Avatar
emtabmm
Wow, and i complained this morning about 8 above 0 f.........that will teach me...
Old Jan 7, 2004 | 05:29 PM
otto's Avatar
otto
hows your trucks heater work in that cold, man I cant imagine that, tho I will say that if there is no wind, I cant much tell the difference from -5 to -15 dont get that cold here often tho, i can tell from 60 to 70 tho, the wind can make the cold alot sicker too
Old Jan 7, 2004 | 05:39 PM
AlaskaPowerStroke
We do not get much wind, that helps. The heater does fine. We have to turn it down sometimes or it will bake you. The defroster does have trouble keeping the windows clear when it is really cold, but does well enough to see.
Old Jan 7, 2004 | 06:30 PM
ALASKAF250's Avatar
ALASKAF250
I was wondering how the trucks were doing up in squarebanks.. I almost picked one up from there but CAL had a nicer one. Keep any eye on the Fan belt might snap in the cold. The 7.3's in Prudhoe do.
Old Jan 7, 2004 | 06:54 PM
AlaskaPowerStroke
Thanks for the tip.
Old Jan 7, 2004 | 08:27 PM
BDU33's Avatar
BDU33
Alaska PS...I had the chance to work in Fairbanks last winter. An old scrap yard, Dirty Petes place,anyways...we never had a prob with our deisels thru the winter, although it was a mild one, the coldest we saw was -40. We had them run all day during that spell. Just my .02 worth. I might end up there again in July...we'll see.
Old Jan 7, 2004 | 11:24 PM
Daryl Hunter's Avatar
Daryl Hunter
How long does it take for the tires to warm up?
I can remember driving in -10 to -20 degree weather in Nebraska growing up and waiting for the tires to stop thumping for the first several blocks because of the flat spot at the bottom of the tire.
But that was a car tire with 32 psi, I guess the truck at 65+ psi wouldn't be as flat.
Still darn glad I live in San Diego now.
Old Jan 8, 2004 | 10:56 AM
dhermesc's Avatar
dhermesc
How does the Ford 6.0 handle #1 diesel, or can it even be used?
Old Jan 8, 2004 | 01:50 PM
AlaskaPowerStroke
We only run #1 after November. There was an issue earlier this year with #2 being sold as #1 and the dealership was full of diesels being thawed out. Cheap fuel is not the way to go.
Doesn't seem to have as much power with #1, runs just fine otherwise. We are looking into the suggested additive.
Tires take a couple of miles before they feel round again. Not as bad with the higher psi.
BDU33: Thanks for cleaning that place up!
Old Jan 8, 2004 | 07:53 PM
BDU33's Avatar
BDU33
Your welcome Alaska PS! I will be back to Fairbanks...just dont know when.
Old Jan 9, 2004 | 05:34 AM
Mizzou's Avatar
Mizzou
Which Cal's location did you go through. I got mine up on 5th and was highly pleased after I got it in from KTP.
Old Jan 12, 2004 | 01:01 AM
al125's Avatar
al125
Did some camping in the Grandcanyon from Dec.29,2003 to Jan 02,2004. the coldest night went down to 6 degree. Had no problems starting in the mornning.
_____________________
03 XLT F250/ supercab /camper pkg/lance camper 815
Old Jan 12, 2004 | 01:34 AM
ALASKAF250's Avatar
ALASKAF250
I got mine on fifth as well. I guess it was a good deal. I know some of the guys up there it's 3rd rig from there.
Old Jan 16, 2004 | 05:09 PM
AlaskaPowerStroke
How are your 'lower 48' trucks running with the cold temperatures? Curious about northeast US.
