Sponsored by: Real Truck
Electrical Problem????
Old Sep 11, 2002 | 11:43 AM
FortyFords's Avatar
FortyFords
[updated:LAST EDITED ON 11-Sep-02 AT 12:46 PM (EST)]Kirk in your first post you said it didn't flash with the lft hd
turn signal as it did with the rthd signal,is it now doing that also and your problem resolved?
That is why I thought you had a problem
Here is how mine is wired if interested
pin 1 male pin( wht wire) =ground
pin 2( br/wht stripe) = marker light only
pin 3(yellow)= lft hd turn/flasher/brake
pin 4(green)= rht hd turn/flasher /brake
Granted i don't know which wires from the light yor adding go to what pins !!!!
Rich
Old Sep 11, 2002 | 04:27 PM
Quikirk's Avatar
Quikirk
Hey Rich. The plug on the light goes to the top pin (rt turn/stop) and the bottom white ground. This would explain why it flashes with the rt turn signal. I didn't realize that there isn't a brake only circuit on this connector. Everything is working as it should and I learned something. I thank you for your help
adrianspringerpc
Mar 11, 2014 07:42 AM
sierra308
Oct 1, 2010 03:27 AM
tesserra
Apr 6, 2009 06:01 PM
M998
Electrical Systems/Wiring
Jan 29, 2007 09:33 PM
T'sFord
General Automotive Discussion
Oct 24, 2004 08:28 PM
