Another question concerning gen/alt.
Old Jan 7, 2004 | 07:07 AM
Okie-Dokie's Avatar
Okie-Dokie
The thread concerning Gen/Alt conversion was getting so long I was afraid this would just be lost. My question is: Is there a fuse block that converts the 12V back to 6V so as to avoid dammage to the heater and wiper motors and the light bulbs, but still uses 12V to charge the battery and start the truck? If so, where is this avail? Thanks!
Old Jan 7, 2004 | 08:24 AM
GreatNorthWoods's Avatar
GreatNorthWoods
It might be easier to look into a six volt alternator. Then you won't need a voltage reducer.
Old Jan 7, 2004 | 02:21 PM
jeffh's Avatar
jeffh
You'd need the voltage reducers, like GNW mentioned, or a 6v alternator. I've also heard of special batteries that run as 6-volt but start the vehicle with more volts. Try some forum searches to look for past posts on these...
Old Jan 8, 2004 | 04:48 AM
GreatNorthWoods
If you have already converted to 12 volts negative ground, I believe JC Whitney has a voltage reducer for about 20 bucks that should work for you.
Old Jan 8, 2004 | 03:01 PM
jmooremtb's Avatar
jmooremtb
Midfifty has a voltage reducer for the gauges and another for the heater and wiper motors. (P 52 in the current catalog). Change the bulbs to 12 v units. It will be nicer with brighter bulbs, anyway.
Old Jan 10, 2004 | 06:05 AM
Okie-Dokie's Avatar
Okie-Dokie
Sorry it took so long to say thanks. Been a real busy week! I will be checking out JCW and the midfifty cats. soon! Thanks again!
A/Ox4
Dec 14, 2012 08:48 AM
rusbukt
18
May 25, 2010 01:43 AM
2pazr
Feb 9, 2009 11:19 PM
e william
Aug 29, 2007 06:50 PM
drtry10
All Things Towing
Mar 9, 2006 10:36 AM
