ok
i just bought a 1992 F350 with a 5.8L and a C-6 trans.
the gas mileage is horrable, i went 60 miles on ahalf of tank.
i checked my fuel pressure and the regulator was bad, reading 85 psi. then after doing that i found out that the truck has a recall on that, up to 150,000 miles
sounds like your have a great truck for towing. if half a tank is 8 gallons your getting close to what i get. try a fresh tune up, cap rotor, plugs and clean the injectors it should get better.
Also are you getting a check engine light if you are your 02 sensor is bad with that many miles i would go ahead and replace it anyway this fixed my prob and i now get 320 miles to a tank of cheap gas HOPE THIS HELPS tune up will help also
i think because mine is a 1 ton truck and no overdrive, i believe that is why i am getting such bad mileage, or that is the correct miles per gallon and i just did not know
