Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2002 shutter when at complete stop
Old Jan 6, 2004 | 10:20 PM
jdh's Avatar
jdh
Question 2002 shutter when at complete stop
I have a 2002 Escape. 1 day after having the tires rotated(may or may not have anything to do with problem) my wife noticed a vibration and noise when at a complete stop. Vibration stops when brakes are let off. It does not do it when in reverse. And sometimes are worse than others. Is this a brake problem or a transmission problem? Any info wouls help.
Old Jan 27, 2004 | 07:04 AM
tara's Avatar
tara
We need help too. We have a 2001, and two weeks after a simple tune up and replacement of shocks/struts it is shuddering while idling and anything below 40 mph. It was quiet at first, but eventually got way worse no matter if we were braking or driving. Having trouble getting the automatic engine to shift right too. They said it was valves in the engine that will cost us over $1000, but we are stuck in Italy with bad mechanics and no Ford dealership to help. If you find anything out please let us know.
Old Jan 27, 2004 | 11:15 AM
gasman6674's Avatar
gasman6674
Have you re-torqed the lug nuts? Are you getting the vibration thru the pedal?
Tara look for broken/loose vacumn lines and also make sure the plug wires are tight and routed correctly
