Manual transmission shifting problems
Thanks,
TE
>transmission. The truck has 115,000 miles. I have started
>to have a problem with shifting the trans. into 1st and
>Rev., all the other gears seem OK at this point. The
>problem only happens when the engine is running. It is next
>to impossible to shift into Rev. and with some effort it
>will go into 1st. I can shift with ease without the engine
>running, so I don't think the problem is in the
>transmission. I have checked the oil level on the slave
>cylinder and it is set to the proper level. I can shift
>into 1st or Rev. and then start the engine, with the truck
>on level ground, the clutch fully depressed the truck will
>"creep" forward or backwards depending on the gear I have
>choosen. I have tried to make a spacer and slip in between
>the clutch fork arm and the slave cylinder to see if this
>might help but it made matters worst. I couldn't get the
>truck into any gear. Any help or suggestion on this matter
>would be greatly appreciated for this is my first diesel
>truck with a manual transmission.
>Thanks,
>TE
hey te, first off welcome to the club!
-nathan
The reason your other gears will go in, is the syncro's are in fact doing most of the work because of the ratio's being close enough.
115,000 miles on a clutch is darn good!
Rich
It is good to know that your problem is taken care of and you're rolling once again.
