Sponsored by: Real Truck
Front end noise
Old Sep 12, 2002 | 01:56 PM
79CEEJAY's Avatar
79CEEJAY
Front end noise
Old Sep 13, 2002 | 01:18 PM
Mscales's Avatar
Mscales
Front end noise
If I lock my hubs in manually to get everything lubed up, the front ends makes a squeaking sound and a slight ticking noise. Unlock the hubs and the noise is gone. Lock in the hubs automatically and the noise comes back. I rotated my tires a couple days again and on the front pass. side there was a little (smelled it before I found it) gear oil between the rotor and the wheel. My truck is also pulling to the right on braking. Anybody else seen this issue before? I haven't taken to the dealer yet because the last time they really made my angry. I am looking for a new dealer to go to at the moment. Thanks for any info.
Mike
Old Sep 13, 2002 | 02:34 PM
Monsta's Avatar
Monsta
Sit. Stay.
Front end noise
Sounds like the hub isn't fully engaging.
Good luck with your new dealer.
Old Sep 13, 2002 | 04:54 PM
Mscales's Avatar
Mscales
Front end noise
How do I tell if it is fully engaged. I locked the hubs in manually and then got out and tried to turn the front shaft and the u-joints at the wheels. Everything seems locked up. There is some freeplay in the front shaft when everthing is locked. It feels the same way if I lock them in automatically.
Old Sep 13, 2002 | 06:14 PM
Monsta's Avatar
Monsta
Sit. Stay.
Front end noise
The actual best way is to remove and inspect. Sorry...
Old Sep 13, 2002 | 08:28 PM
Mscales's Avatar
Mscales
Front end noise
Can I remove them without a manual? I can't find one for my truck yet. Once I get them off what would I need to look for? Damage, worn seals, anything in particular. Thanks.
Old Sep 14, 2002 | 09:46 PM
redranger1's Avatar
redranger1
Front end noise
if you smelled gear oil i would look at my seals and make sure they are ok.
-nathan
