maybe long post , hopefully not too confusing.
94 Bronco,351w e4od trans, is making popping sound from underneath under mild acceleration when in 4x4 high and low range.
Up to this point I have replaced radius arm bushings (with polyurethane), checked recently installed MM manual hubs (auto to manual conversion w/spindle nut conversion kit). Also rechecked wheel wheelbearings.
Next I pulled recently installed transfer case (used bw 13-45) took tc to transmission shop assuming chain was worn/slipping.
trans shop guy says transfer case is A-OK
He also says there's a good chance I got transmission problems.
The trans seems to do ok in 2wd. Although it does have about a two second delay when you pull it into reverse, and sometimes a mushy shift from 2nd to 3rd.
Any other thoughts/Ideas or is time for trans overhaul. thanks Ron
aay? come on guys, I know there are some transmission guru's out there. I gotta think that if it was the trasn it would also act up on 2wd.
Service manager @ ford house says maybe spider gears in front diff. Any input would be great. Ron
The reason I suggested the trans crossmember was because my 95 had a "popping" sound coming from undeneath. Sounded kinda like someone hitting the frame with a hammer. I called the dealer and found out there was a TSB (not recall) on the rivets. They loosened up enough that under acceleration or turning there was enough flex between the frame and crossmember that when everything moved, it "popped". I might be wrong, but I figured $4.00 in bolts an an hours time would be a good place to start. You are right Clubwagon, about the trans. That is a different issue, and these E4OD's make me nervous. But since there are 51 pages on Transmissions on this web site, I hope to learn something. There seem to be some Knowledgeable people on here.
my '91 f150 2 x 4 makes a popping sound like when backing out of the driveway or going slow. i know it's a rivet, maybe on the rear leaf spring hangers. i've seen several posts on loose rivets, and TSB's as another poster said. Also you might check u-joints. there a bit hard to detect sometime, you need to be on level ground , tranny in nuetral so you can push and pull the dshaft at the ujoint, push hard in a up and down and sideways direction. (should be no slack or loose type movement)this might be my problem, not sure. let us know what you find out.... pross
Okay, Replaced all u-joints in the front axle w/spicer. Also replaced ball joints while I was that far in. Also pulled front diff and had it checked out. Also replaced moter mounts. Still made the noise.
Sooo... yesterday I installed np208 transfer case and lo and behold, no more popping and jerking.
