EBPV Staying open
Out of curiousity I shut it down at a stop light and fired it back up and it was no longer engaged .... What controls whether it is active or not...
Or you can take the tube off and clean it out.
Or you can remove the valve, rip it's guts out, seal up the holes and put it back on.
Or you could wire a switch to the valve and operate it manually.
Or you could gut it, cap the manifold, toss the tube and plug the connection into a "dongle" available from SP diesel.
Sorry, did you want options?
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
I was curious because I would assume that once the motor gets up to or close to operating temp the thing should shut off, and it doesn't seem to to do that, yet if you shut it down and start it back up it seemed to be disengaged. Sounds to me like it wasn't working correctly so, I'll start with cleaning the tube
