460 Redline
Old Jan 6, 2004 | 11:19 AM
TruckGuy001's Avatar
TruckGuy001
Question 460 Redline
My '66 F-250 Camper Special has a '73 460. Just installed a tach.
and need to know the max rpm rating. As far as I know, it's all stock w/ 4bbl carb.
Thanks.
Old Jan 6, 2004 | 11:34 AM
airharley's Avatar
airharley
5000 Max with a stock set up. It's all based upon the cam mainly.
Old Jan 6, 2004 | 11:37 AM
TruckGuy001
Thanks Mark...and you got that right about asking for permission!!!
Old Jan 6, 2004 | 04:28 PM
proeliator's Avatar
proeliator
I'd say these motors can tolerate 6k at max rpm. Seen 'em with stock rods spun to that all the time and hold together. Now, if yours is totally stock there isn't any reason in the world to spin it past 5k, as AirHarley said...but they will tolerate more.
Old Jan 6, 2004 | 07:08 PM
pro3qtr's Avatar
pro3qtr
Funny, I heard rod bolts are really weak.
Being a smog engine I would say very little HP above 4500.
So why stress the engine ?
Old Jan 6, 2004 | 10:39 PM
proeliator's Avatar
proeliator
I agree, what with his engine being what it is there isn't any point running it up past 4500-5k.....but I've seen stock rods last easily up to 6k. I've never heard the stock rods in these engines were "weak"...and most other racers I've talked too agree that they are good up to 6k. Not trying to be argumentative, just wondering where you got your info as I can always stand to learn something new.
BTW, I ran stock rods in a 460 for three seasons at 6k pulls with nary a problem. Not that thats where I base my info, just a testament.
Old Jan 7, 2004 | 08:13 AM
bogginf350's Avatar
bogginf350
I have a 468 .040 over with keith black pistons. It is also balanced and it used to see 7000 quite often this was a stock class mud race motor. I used just 78 car rods that were shot peened and polised with arp bolts and never had a problem. Hey... you gotta live a little every now and then
Old Jan 7, 2004 | 07:45 PM
pro3qtr's Avatar
pro3qtr
Was refering to the stock rod bolts tend to be the weak spot, CJ/SCJ had a better bolts for strength.
So ARP rod bolts would be a wise up-grade.
When I dynoed my truck there was little HP being made above 5000 rpm's
Unless U drag race your truck reving the hell out of it is not wise.
(Refering to STOCK engine)
Hope that explains my post better, not a english major.
I will try better.
