Bronco II Ford Bronco II
Sensor Problems??
Old Jan 5, 2004 | 03:09 PM
85B2Owner's Avatar
85B2Owner
Question Sensor Problems??
The other day my engine decided to stay open throttle on me. I shut it off and started again and it was fine, I'm wondering if the TPS would do that if its on its way out the door. It stays idling high for quite awhile, then it kicks down once it warms up good. Every now and again just after I start driving, it starts to chug a bit then it jumps up to its normal idle and all is fine. Could it be the TPS that can cause this. Other than that the truck treats me relly good, it starts with little hesitation when its minus 30 celcius out, without being plugged in. I have an 86 2.9 in an 85 shell with about 205000 kms on the motor in case you need to know.
Old Jan 5, 2004 | 04:10 PM
Ken00's Avatar
Ken00
I would check the throttle and throttle plate to make sure there not binding, then inspect/clean the IAC. The TPS is only measuring how far the throttle is open and if it reved up high something had to be letting all the air in.
Old Jan 5, 2004 | 10:50 PM
85B2Owner's Avatar
85B2Owner
Thanks, I never even thought about the IAC. I'll get it cleaned out when it gets above -33C here.
Old Jan 5, 2004 | 11:12 PM
mrshorty's Avatar
mrshorty
Found this a couple of weeks ago http://www.mightyap.com/hammer/otlotw.htm He describes a sudden acceleration condition associated with a fluctuating idle that they eventually traced down to a bad TPS.
87-XL-Squared
Feb 26, 2016 07:52 AM
White Mountain Goat
Oct 15, 2014 11:13 AM
f1001969mike
1978 - 1996 Big Bronco
Nov 11, 2012 05:10 PM
timdog
1983 - 2012 Ranger & B-Series
Aug 15, 2008 07:21 AM
bluneon
70
Nov 3, 2007 05:32 PM
