TPS low voltage
Old Oct 15, 2014 | 10:45 AM
White Mountain Goat's Avatar
White Mountain Goat
TPS low voltage
That's the code I'm getting on my 93 4.9 now. At first I got a code 47 I think, telling me to change the TPS. When I changed it, the motor still would not idle at all and was running rich. Wound up swapping the MAP sensor with another I had and the motor evened out. That's when I started getting the code for low voltage on the TPS.
I swapped it back out with the old one with no change. The motor runs fine, just idles a little high (@900) and the CEL stays on.
I'm not aware of any way to adjust the voltage. I tried to do a search on here, but have a poor connection. Some body help me out please.
Old Oct 15, 2014 | 11:13 AM
timbersteel's Avatar
timbersteel
Low voltage could be simple as poor connection with the TPS, bad TPS, or weak battery.
TPS output should be around 0.85-1.0 with throttle bracket touching the throttle plate stop screw and around 4.5 volts with throttle at WOT (wide open throttle)
Need to check with a DVOM , with the throttle body plates closed, what you have with key on, engine off.
I cant remember which wires need to be probed. I know the black is the common ground, but there is also orange and green. I believe the green Green wire is the correct one to test. Also check your reference voltage of 5 volts. If it's not within +- 2% of 5 volts, then you need to dig into that as a problem. Also you can check for good 5 volt reference from the IAT or the ECT sensor. See what the reference voltage shows for them and compare. Could also be poor connection to the PCM and if so, then you will chase your tail if you don't fix that 1st.
killergsxr1
16
Dec 16, 2024 10:44 PM
Elisvk
Jun 17, 2014 09:19 AM
wiarde
Apr 5, 2014 07:14 PM
slicker_22
1983 - 2012 Ranger & B-Series
Sep 19, 2006 12:41 PM
Redneckerson
Jul 8, 2002 08:59 PM
