I have to go pull the starter off the truck in the AM, and was wondering what tools to take with me to where the truck is staying until I return. 76 F-150 390 2 BBL A/T. Thanks!
Well, the starter retaining bolts should use a 1/2" wrench or socket. I prefer a socket with about 6" extension for the top bolt. The bottom, can usually be removed with a wrench or socket.
The retainer bolt for the cable is either 5/16 or 3/8 usually. A pair a vise grips just in case someone has buggered up the head on it.
A rag, it's probably greasy by now.
Jimmy
Do you have headers? If you do you're probablly gonna have to drop them to pop out the starter, I had to.You're gonna need a breaker bar to break the header bolts loose and a torque wrench to torque em' back on.But if you have a manifold it, it won't be in your way.BTW Header bolts are 3/8".
