Temp. Gauge Sending Unit
Old Jan 4, 2004 | 06:37 PM
Beast12's Avatar
Beast12
My truck (in sig) runs on the very low side of normal on the temperature gauge. The truck itself actually runs warm enough for the heater to blow hot air. So I am thinking maybe the temperature sending unit is shot. Where is it? And is there a way to test it? Thanks.
-Matt
Old Jan 4, 2004 | 08:05 PM
EPNCSU2006's Avatar
EPNCSU2006
I think Ford has the guages set up to run on the lower side of normal. Mine usually rides just below the 'n' of normal.
The coolant temp sender should be near the front of the intake manifold on the drivers side with one wire going to it. I'm not sure how to test the sender, but you can ground the wire to test the guage.
Old Jan 17, 2004 | 10:31 PM
mudball101's Avatar
mudball101
the sender for your temperature should be cheep. I bought one for my truck for 7 bucks and thats a really expensive place
Old Feb 2, 2004 | 12:25 PM
Beast12's Avatar
Beast12
Well, I tested the gauge by grounding it and it works. So I bought I sending unit directly from Ford and installed it. But alas, it still runs just below the NORMAL line. Hmm....weird. I get some pretty good heat but it still reads low. Any other suggestions or does this engine just run low? I have a thermostat I am going to replace so maybe that will make it run a bit hotter.
-Matt
Old Feb 2, 2004 | 12:27 PM
EPNCSU2006's Avatar
EPNCSU2006
Replacing the thermostat sounds like a good idea. It's not the guage and it's not the sender, so the engine may indeed be running a little colder than it should be. My mechanic always says to get a thermostat from the dealer.
Old Feb 2, 2004 | 12:31 PM
Beast12's Avatar
Beast12
I bought one at the same time as buying the sending unit. I bought it from the dealer as well. I work for my dad's tree business so anytime I go into the dealer they give me my dad's prices. Businesses get stuff cheaper! One time I bought a part and regular price was double what I pay.
So it only cost me $20 CANADIAN for a thermostat, gasket and sending unit. I might do it this afternoon. I'll keep you guys updated.......
-Matt
Old Feb 2, 2004 | 05:53 PM
victorcharlie's Avatar
victorcharlie
I would think you have a corroded connection somewhere. (High resistance) I had the same problem on my truck. Changed the temp sensor and had the same problem. Cleaned the connection and snugged it with a pair of pliers....runs mid scale now. I guess it could be the wire....
