Add-A-Leaf Question
Old Jan 4, 2004 | 02:50 PM
Stinger_916's Avatar
Stinger_916
Add-A-Leaf Question
A sagging front end on my 97 250 has been bothering me for some time now and I want to install the add-a-leaf system but I hear that castor/camber bushings maybe required. Have any of you installed this system before and did you need these bushings?? Also is this a job for the shade tree mech or should I have a shop do it??? Thanks for your time.
Old Jan 4, 2004 | 11:05 PM
bender97f250's Avatar
bender97f250
Same truck,same problem. Camber blocks will cost you about $36.00 each. Labor will take you about 1 hour each side, plus the cost of a frontend allignment. Removing the oem blocks can sometimes be a picnic on a rainy day! Total bill aprox. $230.00. If you have tools and you are mechanically inclined I dont see why you could do this yourself. You must decide if spending the $$ is worth the added time and effort. It helps if you have acess to a lift. As far as the addaleafs, I left mine untouched. You can thank gravity and the weight of the engine for the frontend sag.
Old Jan 5, 2004 | 07:33 AM
f350xlt460's Avatar
f350xlt460
my expirence with add-a-leaf kits (on a land rover) is that they are the hardest kind of lifts to install. Id much rather just remove the whole spring assembly and replace it.
just my opinion.
Old Jan 5, 2004 | 08:06 AM
Hope Springs Hauler's Avatar
Hope Springs Hauler
I did an add-a-leaf and it took me about 45 minutes to do. The hardest thing to do was get the old center pin out. Cannot advise on TTB frontend as I have a Monobeam.
PS Soak the ubolts about a day ahead of time to get the best oil penetration
