diff oil
Old Jan 4, 2004 | 12:36 PM
ford429cu's Avatar
ford429cu
diff oil
I have a 99 Ranger 4x4 4.0 off road pakage and I am planing on changing the oil in both diffs. I was wondering if anyone knows what weight to use and how much each diff takes?
Thanks,
Jeff
Old Jan 4, 2004 | 01:10 PM
Mike W's Avatar
Mike W
Use 90 weight gear oil. How much.....I am guessing 3 quarts. If you have limited slip, you need a bottle of the friction modifier for each.
Old Jan 4, 2004 | 03:44 PM
Dealford's Avatar
Dealford
Check the ID tag on the diff to find out if it is a limited slip. The gear (eg.410) should have the letter "L" with it to signify Limited Slip.
Old Jan 4, 2004 | 07:24 PM
Hank85713's Avatar
Hank85713
although pricey think about the mobil 1 synthetic. I just put it in the diff (75w90) and they have a heavier one also. I also put the valvoline synthetic ATF in the gearbox, shift real slick now.
94 4.0, 2wd 5 sp.
Hank
Old Jan 4, 2004 | 08:06 PM
irazu's Avatar
irazu
What happens if you dont put the frition modifier in the limited slip?
Old Jan 4, 2004 | 10:10 PM
Rockledge's Avatar
Rockledge
You might feel some "chatter" from the back end as you go around turns. That's the limited slip axle being too aggressive. The friction modifier helps with that.
But keep in mind, you want to use as little of the friction modifier as possible in order to retain maximum limited slip action. So if you have no chatter, then leave your diff fluid alone and don't add anything. If you do have some chatter, then you want add a little bit of the modifier, drive around test it, add more if necessary or don't, as the case may be, etc., until the chatter is gone. Less is better in this case.
Old Jan 5, 2004 | 08:25 AM
rangersvt04's Avatar
rangersvt04
same wight in a 2 wheel drive model??
