charging system problems
Old Jan 4, 2004 | 10:06 AM
captain redneck's Avatar
captain redneck
hey all
well where to start
when i bought this truck 1980 ranger lariat
it was missing the regulator, so i got a new one
well right away the new battery i bought was dead after sitting over nite
so i checked and my cables would spark when i rubbed it against
the battery post
definate short, so i searched and searched
and never could find the short
so i just started unhookin the battery over nite
well this worked fine for several months
then it started that the battery wasnt holding a charge any longer
ok so im out driving, and i smell the battery
that sucker was overcharging yet wouldnt hold a charge
anyway i get out and unhook the battery cable and wrap it up
tryin to get back home, and not blow up the battery
it was still runnin ok, i got in the truck and drive bout 20 feet and
it died, and now it just turns over when i try and start it(with a jump)
as u can guess its about to get drove in the river and left for dead
unless someone has any ideas how i might fix this complicated mess
any ideas at all are welcome.....
Old Jan 4, 2004 | 10:37 AM
Jens's Avatar
Jens
Hi,
first of all welcome to FTE.
The first thing what you should do is to check the charching power with an amperemeter.
To check for a short, unhook the neg. cable, use a test light between the neg cable and the neg port of the battery. If the testlight glows up there is the short in you electrical system.
To find out where it is...just pull the fuses, one by one until the testlight goes out.
You wrote you bought an new regulator, is this Regulator properly installed, is the Reg. connechted to ground?
just an idea....
Jens
Old Jan 4, 2004 | 10:52 AM
captain redneck
hey thanx for the welcome : )
ok i didnt use a test lite
but the short is big enough that u can see the spark when rubbing the neg cable against the post
i did the fuse thing, and it sparked still with every fuse gone
one at a time of course
and i also looked at power wire to starter
and theres no bare spots anywhere on that wire
is it possable for the solenoid to cause a short?
the regulator is pretty much idiot proof, one plug goes in one way
my thoughts are that short killed the regulator
is that possible?
Old Jan 4, 2004 | 11:01 AM
Jens's Avatar
Jens
Yep, that could be, the regulator is very sensitive, I kill mine only by operating without ground connection.
Jens
Old Jan 4, 2004 | 03:32 PM
captain redneck
ok so my biggest question is
why the heck wont it start now?
Old Jan 4, 2004 | 10:49 PM
captain redneck
i see everyone else loves electrical problems bout as much as mee :/ .....
Old Jan 6, 2004 | 12:25 PM
captain redneck
just to let ya know
the ignition module was the culprit
it was my short, it killed my regulator
then it died altogether
Old Jan 6, 2004 | 12:36 PM
Jens's Avatar
Jens
Hey capaitn redneck,
nice to hear that everything is fine now.
Jens
lign
Oct 19, 2013 01:37 PM
cree92831
18
Oct 9, 2013 03:14 PM
Freaksh0w
25
Aug 28, 2010 04:35 AM
crowtf
Aug 1, 2007 01:18 PM
kochy54
15
Apr 21, 2002 05:31 PM
