tcase conversion elect -> manual?
Old Jan 3, 2004 | 10:21 PM
randman59's Avatar
randman59
OK, I am tired of fixing the glitches with my Borg Warner 1354 Electrical Tcase servo motor. Can anybody advise on converting this to a manual shifter? The last fix hopefully!!!!
1994 Ranger Sport 4x4 - 4.0l - 5sp manual.
Old Jan 4, 2004 | 12:59 AM
AlfredB1979's Avatar
AlfredB1979
Yank out the t-case switch on the dash, likewise with the t-case and bit of wiring with it, and swap manual t-case in same spot. Pop out the plate in the tunnel and cut carpet to get shifter through the tunnel. Plug manual t-case harness in and you are pretty much done, if memory serves correct.
I'm not sure about any driveline adjustments, since the t-case was made to sit on the same x-member in the same spot under the truck, so I think things can stay the way they are in that regard.
Old Jan 4, 2004 | 02:18 PM
randman59's Avatar
randman59
I was hoping to not replace the whole tcase, just the shifter. Maybe we sometimes hope for too much.
