This is my first time on this forum and I am amazed on how much info is on here. I recently finished a 351M to 408 conversion. It was fun and a lot of work. My question is, I had a 600 CFM Edelbrock performer on the 351 before I started. It ended up on my 408, my 408 has a higher compression ratio and an Edelbrock cam. I found a set of flat top Dynagear pistons bored 30 over, those were hard to find. Anyway, would the 408 peform any better with a 750 cfm or would it just be a waste of money. Thanks.
Correct formula for finding cfm is:
(cu. in. x rpm x V.E.)/3456 = cfm
or in simpler terms:
408 x 5500 x .90 = 584.375 cfm
According to the formula, it only needs a 600. But Cleveland based engines, which we all know include 351M/400's, like larger cfm carburetors, just adjust your jetting and accelerator pump circuits accordingly. For good street and trail use a 600 is fine, but if you really want to ring it out above 6000, I highly recommend a 750-850 cfm carburetor.
