Sponsored by: Real Truck
4R100 maintenance
Old Jan 3, 2004 | 09:11 PM
MX429's Avatar
MX429
4R100 maintenance
This is the first truck that I have owned that has had a drain pug in the transmission pan. WoooooHoooo!!!!! I just changed the filter and it was a breeze compared to taking the bolts out of a pan and getting an atf bath while laying on the ground.
I chose not to refill with synthetic and I think instead I will make dropping this drain bolt a normal maintenance item when I change my oil. Not only will the truck get a crankcase full of fresh oil, but it will get good dose of fresh tranny fluid also. I figure that doing this regularly will insure that the tranny fluid remains fresh. Do any of you do this regularly??
Old Jan 3, 2004 | 10:06 PM
ssls6's Avatar
ssls6
That's the exact way I did it my last Toyota Tundra. Draining the tranny pan removed 3 of the 13 total quarts in the system. I was changing the oil every 3k miles so in 30k, I did my 3/13 quart mini flush ~10 times. It takes at least 10 times to be almost the same as a complete flush. Wasteful (30+ quarts) but it works.
Old Jan 3, 2004 | 10:09 PM
Munkey's Avatar
Munkey
Hmm, you know, thats not a bad idea at all!! It would get expensive for me though, I'm using Mobil 1 ATF.
Oh wait, I'm already paying top dollar for Mobil 1 oil, so why not on the ATF too right!?!
Old Jan 3, 2004 | 11:14 PM
99f350sd's Avatar
99f350sd
I think thats a great idea...Just check it when warm and top off. Don't overfill..
Old Jan 4, 2004 | 12:03 AM
DS02F250's Avatar
DS02F250
Re: 4R100 maintenance
Do any of you do this regularly?? [/B][/QUOTE]
I do it twice as often as is recommended in the maintenance schedule. I don't see myself changing tranny fluid (partial or full change) every 3K with the oil changes, but I'm happy with changing it every 30K vs. every 60K.
Just my $.02
Old Jan 4, 2004 | 08:17 AM
Berol's Avatar
Berol
Isn't the recommended Serivce interval 30k, not 60k?
Old Jan 4, 2004 | 08:53 AM
95CobraR's Avatar
95CobraR
I was reading the owners manual on my F350 and it did not mention changing the 4R100 filter. It just mentions changing the fluid.
I always understood on my old EAOD that they didn't have a drain plug because they wanted you to drop the pan and change the filter.when you changed fluids.
I am a fair Ford mechanic but know nothing about automatics. Any Ford certified 4R100 mechanics around here?? What do you think?
Old Jan 4, 2004 | 10:23 AM
78fordman's Avatar
78fordman
I was talking to the local shop mechanic the other day, he told me that he never changess the filter, just hooks it up to his transmission flush machine and pushes all of the stuff backwards and out of the transmission, now that scares me. I would rather pull the return line and flush the tranny with new fluid that way, plus a new filter. The flush is great but he uses the old filter when he is done, wouldn't they get weak after 30k? Plus he want 60 dollars plus fluid cost for it. I would rather have someone up top, me under neath, holding the return line in the bucket and tell him to add more fluid, than push all of the garbage back into the tranny.
That just my $.02
Old Jan 4, 2004 | 01:11 PM
VolvoWrench's Avatar
VolvoWrench
78',
I think what your mechanic actually meant was more like what you're talking about doing. I don't think the machine will literally push the fluid backwards. I have this machine at work.
Basically, you un-plug one cooler line from the trans cooler and hook it to the machine. The dirty fluid goes in one side of the machine and as it's going in, the machine is pumping fresh fluid out of the other side of the machine into where you un-plugged the cooler line from. Even though $60. sounds kind of high, it is the best way to completely flush a tranny. It gets all the fluid out including the torque converter and it's not messy. The cost of the fluid you'd have to pay for one way or the other.
Pete
Old Jan 4, 2004 | 05:11 PM
V10man's Avatar
V10man
MX429,
Next time drain the TQ converter too. Remove rubber plug and look for a 1/4" pipe plug in the converter. (you will have to trun the converter to line up the plug/hole) You will get out all but 1 or 2 qts of fluid. 30K is the recomended change level. I changed my fliter at 30K but haven't changed it since. Did a drain and refill at 60k, a flush at 90k and will propbably do a drain, filter change at 120K. You may want to think about adding a few mods to your tranny while you have the pan off. Very easy. The tricumulator springs, sonnax valve or Diablo valve really firm up the shifts. For abut $50 really worth it.
Old Jan 4, 2004 | 06:29 PM
MX429's Avatar
MX429
The filter is in the tranny to clooect particles. If it collects enough particles, it gets dirty and possibly clogged. Just flushing doesn't address this. I would rather just change the filter rather than just flush it.
I tried some B&M springs in my last truck with an E4OD. It really firmed up the shifts, but they were too firm for me. It snatched into gear too hard and I didn't think it was worth the stress on the driveline while towing.
Old Jan 5, 2004 | 08:40 PM
GreatWhite02's Avatar
GreatWhite02
I'm looking to improve the shift firmness on my 02 PSD. Can someone explain the differences in a shiftkit verses tricumulator springs & diablo valve.
Old Jan 5, 2004 | 08:54 PM
78fordman's Avatar
78fordman
Diablo valve will help the overall line pressure, not raise it, but help the flow. My 4 speed 4r100 shifts 5 times, because the line pressure drop, due to too small of line pressure regulator, not enough oil can get through it, so a diablo line regulator is larger, and will help with a firmer shift.
Old Jan 5, 2004 | 09:00 PM
GreatWhite02
But wont the shiftkit do the same thing.
Old Jan 7, 2004 | 07:00 PM
78fordman's Avatar
78fordman
Yeah, but the regulator is a cheaper way of getting simular results.
