Edelbrock Adjustments
Old Jan 3, 2004 | 02:07 PM
Swampdonkey09's Avatar
Swampdonkey09
Question Edelbrock Adjustments
I have played around with trying to get my 390 to idle a little better, had a buddy of mine look at it and he screwed around with the adjustment screws on the front of the carb, now i dont know where to put them back to, any help would be appreciated. its an edelbrock 750 cfm, if that helps any.
I bottomed the screws out and then played with them until it sounded pretty good but i want to make sure that the settings are right.
Thanks Swampy
Old Jan 3, 2004 | 02:14 PM
fordeverpower's Avatar
fordeverpower
1.5 to 2 turns for both.
Old Jan 3, 2004 | 05:04 PM
Swampdonkey09
thanks for the help, just tried it and it runs alot better, he had them turned out about 4 to 4.5 turns, maybe thats why it wouldnt idle for crap
Old Jan 3, 2004 | 05:09 PM
fordeverpower
hey i have a 600 edelbrock and 1.5 is good but 2 turns and if i stomp on the pedal at a stop the truck likes dies but if you ease into to pedal while smashing it to the floor, if such a thing, its fine.
Old Jan 3, 2004 | 05:11 PM
fordeverpower
by the way those screws are air fuel mixture screws not idle screws so it should make a big difference. the idle screw is on the throttle linkage.
Old Jan 3, 2004 | 06:33 PM
78fordman's Avatar
78fordman
What do those screws control, isn't the left one ldle mixture, and then the right one running mixture?
Old Jan 3, 2004 | 06:37 PM
fordeverpower
i have been told that both are mixture screws that only affect low speeds. So if you are running lean on top end it doesn't seem that you can adjust. I was under the impression that the screw was for that side and the other screw for its side.
Old Jan 3, 2004 | 09:09 PM
ACESN8S's Avatar
ACESN8S
I was under the impression that one was for the primaries, and the other was for the secondaries. But I could never get a straight answer on the Edelbrock carbs. Especially why the diagram showed the port and timed vacuums opposite of what the actually where on the carb. I bought one when they first started coming out, maybe things have changed. But the best adjustment I ever made to one of their carbs, was going back to a Holley.
Old Jan 3, 2004 | 10:56 PM
swann79's Avatar
swann79
fordeverpower is right... the screws are for the low-speed circuit in each of the primary "barrels" of the carb... they only effect your idle and off-idle mixture. Adjusting mid range and wide-open throttle requires changing the jets along with other mods.
Here's the best way I've found to tune the idle mixture on any carburetor:
1. Start at 1 1/2 turns out if this is a new install.
2. Work with one screw at a time.
3. Turn it in until the engine just starts to slow down, then back it off a little bit. NOTE: Your final turn should always be IN on a spring loaded needle, so back off a little more, then turn it slightly in.
4. Repeat the procedure on both screws 2-3 times, as final adjustments will be needed.
This will basically set your idle to run as smooth as possible with the leanest mixture possible, which is the desired effect if all other parts of the engine equation are functioning correctly.
Also try to keep the idle speed close to specs while doing this.
This technique has worked for me on several carbs, from the 1 bbl on an I-6 to a Holley 4 bbl 1250 double-pumper.
Old Jan 4, 2004 | 01:08 AM
biz4two's Avatar
biz4two
I thought to adjust the secondaries go with the spring loaded screws in the back of the carb. Is that right?
The cool thing about Edelbrock carbs...that re-jetting is so simple and does not require removing the carb. Also, once I installed the off-road or 4x4 needles...the carb has worked flawlessly. I had a holley "once"...but just wasn't for me or my FE. To much adjusting.
Old Jan 4, 2004 | 03:49 AM
ACESN8S's Avatar
ACESN8S
I gave up on them, I even had a friend who built up Carters tear into it, still no luck.
But after reading the other post, https://www.ford-trucks.com/forums/s...hreadid=188228 , and thinking back, most of the problems I had were with the "blended fuels" they used where I used to live. The fuel service that I had used actually got nailed for using more than a 10% mix of ethanol. But by that time I had already switched back to a Holley and wasn't having any problems.
Old Jan 9, 2004 | 01:25 PM
Swampdonkey09
thanks guys for all of the response, the old hawg runs like a top now. cant wait for spring thaw to start throwing some good ol maine mud around
