I must have gunk in my oil pan, cause the pressure is on the "N" on the word normal, not in the middle like it usually is, i put some MMO in it and after a couple miles of driving it went back to the middle like normal.
If that stuff really works that good i might get some. Mine takes 5 quarts of oil. Can i get a gallon of oil and a quart of MMO to put in for preventative maintenance?
yeah, i got a quart and put in 8 oz into the gas and the rest into the crankcase, worked good, i cant guarentee you'll see results, i'm going to change my oil and drain the gunk out it loosened up.
