Question from new guy....again
Old Jan 2, 2004 | 11:55 PM
PDawson's Avatar
PDawson
Question Question from new guy....again
Im wanting to keep everything original or close to as possible on my 64 f100.
Would it make any sense to change oil bath to paper , and change generator to alternator?? I have a 223, and I feel that everything should be fine the way it is, but if you guys have any insight from your experiences, I'd like to know about em....
Thanks,
Phillip
Old Jan 3, 2004 | 02:48 AM
Andysutt's Avatar
Andysutt
Honestly, I would upgrade those
They both work, but they went out for a reason.
It wouldn't make your truck worth any less in my opinion
Old Jan 3, 2004 | 06:00 AM
jowilker's Avatar
jowilker
If they have worked for 40 years, they'll probabally work for a few more.
John
Old Jan 3, 2004 | 06:58 AM
ddavidv's Avatar
ddavidv
The only reason oil bath air cleaners 'went out' is they are messy and require maintanence. They are equal to or better than a paper filter as far as keeping junk out of your engine. I've retained mine on the 352 and don't plan to change it. Servicing the oil is easy enough.
Gen vs. alt, I think the only reason to change to an alt would be if you needed more charging power.
Old Jan 3, 2004 | 08:11 PM
Andysutt's Avatar
Andysutt
I didnt mean they went out as in quit working
I meant a new design
Old Jan 8, 2004 | 09:05 PM
PDawson's Avatar
PDawson
Sorry for not posting sooner---
Thanks for the advice.....I may go with the original stuff once I begin to restore it. For now, Im just going to mess around with whatever I find at boneyards................
Thanks again!!
Old Jan 9, 2004 | 12:42 AM
minishtr's Avatar
minishtr
I also have a 64.I have a paper air filter because the orginal is long gone.I'm in the process of getting the parts togather to convert it to a one wire GM alt.
Brian
Old Jan 9, 2004 | 09:48 AM
6t6merc's Avatar
6t6merc
I wanted the original look without the mess so I hogged out the upper half of the oil bath unit and put a cheap chrome aftermarket assembly with paper element inside the two halves of the canister. Fits perfectly. I think it's 8" in diameter.
Eric
Old Jan 9, 2004 | 10:23 AM
lsendel's Avatar
lsendel
6t6merc
How did you remove the inside of the upper half on the oil bath? Might like to try it.
Old Jan 9, 2004 | 12:19 PM
6t6merc's Avatar
6t6merc
I used a Zipcut to cut the webs between the oval holes and cleaned up the sharp edge with a grinder. I had anticipated that I would have to use the aftermarket bottom half, and simply hang the original, modified top over the whole works, but the cheap chrome piece fit into the original bottom like it was made for it. The height of the whole assembly is determined by the thickness of the paper element. (You might want to measure an unmodified unit to determine how much of the bottom half should be exposed.) I used the original stud and wingnut.
Eric
Old Jan 9, 2004 | 02:19 PM
Andysutt's Avatar
Andysutt
Brian
Check out my post on FE board, and 61-66 board on the 2 wire tempo alternator
Stock brackets, 2 wires, internal regulated, and fanned, and its 95 amps
Old Jan 10, 2004 | 12:48 AM
minishtr's Avatar
minishtr
I know a GM part on my Ford.I seen your post and it got me looking in the junkyards.I have a 223 in my truck and I could not find any Ford brackets that would work.There was a chevy truck with a six with a bracket and alt that would work with minor mods.
Brian
Old Jan 10, 2004 | 02:11 PM
Andysutt's Avatar
Andysutt
Hrm, I dont know much about the 223s but wouldnt the stock mounts on your block work?
