300 efi buildup
Old Jan 2, 2004 | 09:06 PM
fordman300's Avatar
fordman300
300 efi buildup
I am going to be rebuilding a 300 efi motor sometime soon and i was wandering if anyone had any suggestions. I'm not sure what cam im going to use yet but im looking at the comp cams 260H grind. i want lots of lowend torque but i also want some ponies too. I am planing on having a 2 stage chip burnt also one for 89 octane and the other for 93.
I'm planning on a standard overhaul, rod, main, + cam bearings, pistons, rings, + cam with these addidtions
having the crank turned .010 on the rods and mains
having the head shaved .010, port n polished, and a 3 angle valve job
bolt down rockers replaced with 3/8 screw in studs to run 1.75 ratio chevy 250 rockers
having the block boiled, new cam bearings installed, bored .030 over, and zero decked to up the compression and create .042
optimum quench
solid metal timing set
brass freeze plugs
camshaft and lifters
distributor drive gear
oil pump
msd 6AL ignition box wit a MSD blaster 2 coil
19 #/hr injectors
adjustable fuel presure regulator
351 throttle body
any suggestions would be greatly apreciated
Old Jan 2, 2004 | 11:51 PM
steell's Avatar
steell
Looks good, but I am not to sure about the 351 TB and the chip thing. There is a EFI expert (I think at www.ford-truckss.com) who's nic is Fireguy. Might want to post over there and ask his opinion.
Steve
Old Jan 3, 2004 | 11:46 PM
optikal illushun's Avatar
optikal illushun
hey, remember me? lol. i was considering the larger TB myself but it wont be much improvement. i may have to look up that fellow when i get my chip.
79-F350
18
Feb 27, 2014 04:20 PM
F-250 restorer
68
Jul 7, 2009 07:25 PM
Ranchero460
Aug 16, 2006 01:05 PM
GHog
34
Dec 29, 2004 06:39 PM
fordman300
Computer Chips & Tuners
Jan 5, 2004 07:51 PM
