Won't start
Old Jan 2, 2004 | 06:52 PM
Ice 9's Avatar
Ice 9
Won't start
I swapped a 79 mid sized car 302 in place of the tired 351 m in my 78 f 150 4x4. It wont start and back fires through the carb. I am thinking maybe the 351 truck ignition module is not compatible with the 302 car distributor or maybe the 15426378 counter clockwise firing order from my Chilton manual is wrong for this motor. Before I start hunting for ignition or cam timing problems I thought I'd ask for help on this forum and that there might be something simple I'm missing.
Old Jan 2, 2004 | 09:14 PM
gcfisher75's Avatar
gcfisher75
sounds like it could be 180 degrees out of time, try spinning the distributor around and seeing if that helps. Did the motor run b4 taking it out of the car? If so was the dist. messed with?
Old Jan 2, 2004 | 10:48 PM
biz4two's Avatar
biz4two
I agree with gcfisher75. Sounds like it is out 180 degrees.
Good luck with it.
Old Jan 3, 2004 | 02:30 AM
fordeverpower's Avatar
fordeverpower
the firing order sounds good. Its definately sounds like a timing problem.
Old Jan 3, 2004 | 08:39 AM
Ice 9's Avatar
Ice 9
Thanks guys,
It is a junkyard motor ( when will I learn) they said it ran when they parked it and the distributor did not look like it had been disturbed so I thought it must be something I've done . I'll set the dist. on #1 TDC and see what hahappens.
Old Jan 4, 2004 | 12:20 AM
kermit's Avatar
kermit
firing order is definitely right, i have those numbers glued to my memory from my 77 which had a 302, but i wonder if the distributor didnt look moved, maybe the timing chain is stretched and has jumped a tooth? just a thought.
Old Jan 29, 2004 | 05:28 PM
woodstockaz's Avatar
woodstockaz
If you guys figure this out let me know. I have the same problem right now, the backfire through the carburator is actually just gas, no fire in mine. The distributor was messed with, but is is at the number one with tdc. ???????spark is good on all plugs.
Old Jan 29, 2004 | 10:26 PM
Ice 9's Avatar
Ice 9
As it turns out the distributor had been out of my motor and when it was put back in it was put back in 180 degrees out of phase so yes it was firing on the #1 cylinder but on the exhaust stroke. Set yours up to fire on the intake stroke # 1 tdc ( both valves closed and it should solve your problem.
Old Jan 30, 2004 | 02:03 AM
Matts72's Avatar
Matts72
The 351M igntion module has the same part number as the 302 igntion module. So they are compatible.
You might want to have it tested anyway.
