Sorry, about what i said, I didnt explain my self clearly. I meant that I need to know where each fuse goes, on the fuse box and what size amp each one needs be to be. Sorry about that.
hmmm, My 82 and my 83 have it on the holder it self, that why I figured it did'nt change.
Maybe check your manuel, I don't have mine, or maybe get a haynes manuel.
The haynes manual#36058---(1980-1996bronco and f-150) shows no locations of exact fuse identification (map as u would call it ).It only shows later models . Consult your owners manual or mabey someone with a 1984 can help ya out .---TR
If you send me your email address, I will email you the wiring schematics to your truck. In there it will show the fuse box, what goes to what, and the amp rating. If you post your email in here for me, the forum policy will remove it instead of posting it. Unless you replace the @ symbol with something else. Otherwise there is a way somehow that you can email me direct thru the forum and then I can reply to you.
