"I need a new Serta" for my '66 LB
Right after buying my '66 Long Bed, I started posting questions and was greatly amazed at the amount of response. I thank one and all for your help and advice.
One of the members here was quick to provide info and suggestions re my "bed" problem. I skimmed over and figured I would get back to it later. I am now unable to find his response.
This is my problem: the bed is "ate up" at the front, about 6" and almost all the way across. The tail needs about 3" fix.
I have searched for panels (they don't exist). I have looked for CHEAP donor trucks for just the bed (TAKE OUT A LOAN). I even had one gent with a parts truck offer to cut the sections but again, TAKE OUT A LOAN.
I am not asking for much. Should I cut the whole bed and put in plate steel, then "Rhino It"?? Should I go the show route and cut out the whole bed and then put in wood (rather expensive regarding the cost listed on the web).
I don't want to lose this project - the rest of the truck is GREAT - it's just the bed where water has sat in the bed and rusted through.
Please folk, I need all the help I can get.
Thanks in advance.
BTW - putting in engine 1 Feb
Thanks in advance.
on
1 Post
<cr>
Sounds like your problem isn't a "how to do it" issue but more of a "should I do it" issue.
You can't have your cake and eat it too. If you want a good looking restoration, you spend the money. There's no way around it.
Personally, I would look around for a new bed. My second option would be to get those panels from the donor truck. I would save my pennies until I could do that.
If I didn't care and just wanted a rig to drive around, I'de probably buy a couple sheets of 3/4" plywood, & cut them to size. If one of my buddies called the results ugly, I'de say, "You know what, it does. How about loaning me the money to fix it."
wezol5484
12-26-2008 04:46 PM
jozs56ford
05-22-2002 08:53 PM
