dim parking light
Old Jan 2, 2004 | 04:01 AM
87joe302racetruck's Avatar
87joe302racetruck
dim parking light
ive got a slight problem the passenger parking light is extremely dim and the rest are fine. ive check the bulb nothing seems to be wrong. also every once in a while my right turn signal indicater will come on and stay on unless i turn the signal on then it goes to normal until turned off. just wondering if anyone else has had this problem. also is it normal for the hazard lights to stop blinking when i put on the breaks. i had to get towed home one day cause my coil blew up (brand new 2 weeks before auto zone parts are *****)
Old Jan 2, 2004 | 06:21 AM
richierich45's Avatar
richierich45
Sounds like a ground problem. Maybe someone on this board can tell you where those lights are grounded.
Yes, the flashers stop when you hit the brakes.
