Sponsored by: Kumho
truck height
Old Jan 1, 2004 | 07:46 PM
guillermorivera's Avatar
guillermorivera
truck height
Can someone look at a pic of my truck in my gallery and tell me if it sits too high in the rear. The suspension is stock and so are the tires (235/75/15). Thanks.
Old Jan 1, 2004 | 08:00 PM
Menroid's Avatar
Menroid
It does look like it sits higher in the back than other similar trucks I have seen, but it is still a nice looking truck.
Old Jan 1, 2004 | 08:13 PM
Gobstopper909's Avatar
Gobstopper909
now that you mention it, it does look a little high. Maybe the previous owner added a leaf or got the leafs re-arched for carrying a load
Old Jan 1, 2004 | 08:26 PM
Gobstopper909
Old Jan 2, 2004 | 01:17 AM
biz4two's Avatar
biz4two
Actually looks pretty normal for a FORD truck. Keep in mind that FORD designed their trucks to carry a load. With that in mind...the rear is usually 2" higher than the front. Measure both front and rear fender openings from the tire to the bottom of the fender. If it is within the 2" mark...then all is normal.
If not normal...as others have mentioned the previous owner may have added an add-a-leaf or an extra leaf in the pack. Something also...if using gas charged shocks in the rear will help push up and make it look higher.
Please post back...what you find.
Old Jan 2, 2004 | 01:44 AM
MrDeath8666's Avatar
MrDeath8666
Bingo, biz4two hit it right on the mark. Ive seen many F150s that sit higher in the rear, more rake. Doesnt bother me too much, except on mine being lifted it looks a little weird.
Old Jan 2, 2004 | 03:07 PM
guillermorivera
I put on new (stock) springs in the rear last month. Is it possible they need to settle. The rear measures 36 5/8 and the front measures 33 5/8. How do I know if the shocks are gas charged?
Old Jan 2, 2004 | 03:28 PM
biz4two's Avatar
biz4two
An easy way is to remove a rear shock. If it wants to expand all on it's own, then chances are that they are gas charged. If you push it down and it stays compressed or has little resistance...then probably not gas charged.
Could be they need to settle, but my guess is the front springs are the ones that have "settled". Most after market 4x4 companies (SuperLift, Rancho, etc.) make a 0"-1" or 0"-2" front coil spring. These springs ride like if factory in most cases and usually between $99.00 - $120.00. The install is straight forward and usually an alignment is all that is needed after. Just something to consider...
Old Jan 2, 2004 | 03:37 PM
guillermorivera
Thanks for the info Biz. So the coil springs you speak of don't require any aditional parts for a 2" lift of the front end?
Old Jan 2, 2004 | 11:36 PM
biz4two's Avatar
biz4two
According to Superlift http://www.superlift.com/ that is correct. A simple remove the tire, remove lower bolt of shock, remove lower bolt spring and then upper bolt spring. Install in reverse order. Very easy...BUT make sure to check shock travel after the install. You may need longer shocks...but that all depends on the shocks you currently have.
Also, for the 0"-1" Rancho setup...no additional parts needed. Just the alignment. This is from personal experience on the Rancho springs.
I would recommend the Superlift for a smoother ride and the Rancho setup for firm/stiff.
Good luck with it!
Old Jan 3, 2004 | 12:24 AM
Texan1983's Avatar
Texan1983
shocks can't really alter ride height, and all new shocks should expand on their own, if not then that usaully means they are shot and need to be replaced. just thought you might want to know.
Old Jan 3, 2004 | 12:59 AM
RBrendel's Avatar
RBrendel
yeah the shocks do not lift nor drop. the suspension itself is the cause of this, you say you put new springs in, thats prob the reason. they should settle a little
Old Jan 3, 2004 | 05:01 PM
guillermorivera
Biz, thanks for the info.
I am having trouble with "superlift's" site (my computer keeps debugging and won't let me navigate it), do they list their pricing for those springs or does any on-line retailer list these springs for a decent price? if so please provide a part # for me.
The lowest I've been able to find was for the Rancho springs (part # RAN6418) through 4Wheelparts.com but they were $134.99. Any suggestions?
Old Jan 4, 2004 | 12:19 AM
biz4two's Avatar
biz4two
You are right about Superlifts website...it isn't really good and gives conficting info. Plus...I couldn't find part #'s.
I just found that the 1"-2" lift includes springs and Superlift adjustable camber/caster bushings for alignment. Since lifting the truck causes positive camber angle (tops of tires lean out).
Superlift website lists the following for mail order:
http://www.ntwonline.com (I've used them in the past. Good service)
http://www.4WheelersSupply.com
Skyjacker also makes 1.5"-2" coil springs.
Part # 182 1.5-2" COILS 80-96 F150/BRO 1 PR
http://www.skyjacker.com
I would suggest you call them. Most websites will not show the 1"-2" lift coil kits.
Hope this helps...
MurderedoutF2
6.4L Power Stroke Diesel
Apr 13, 2008 11:14 AM
swirk
May 2, 2002 08:01 PM
fatdaddy
Dec 24, 2001 06:19 AM
fatforty
Paint & Bodywork
Oct 20, 2001 05:30 AM
dslman
Aug 5, 2001 11:46 AM
