Timing/Gas mileage
Old Jan 1, 2004 | 11:13 AM
siphor84's Avatar
siphor84
Timing/Gas mileage
My timing on my EFI 351w is at 13 degrees right now. Would bumping it up to 10 help gas milage, and isn't it true that anything lower than ten would require a higher octane because you are reducing the amount of time the fuel has to ignite?
Old Jan 1, 2004 | 03:04 PM
daerhldgs2's Avatar
daerhldgs2
you're going the wrong way try increasing it to 14-15 which seems high for a gas engine.If it is hard for the starter to turn over or you get preignition back it off until it runs smooth.
Old Jan 2, 2004 | 08:31 PM
fordeverpower's Avatar
fordeverpower
yeah man you got it all backwards. 10 is like factory and 13 is advanced timing and yes more advance causes ping and might require more octance. put it at 10 btdc and you will be good. More advace increases power, and gas mileage but you don't want pinging.
Old Jan 2, 2004 | 08:34 PM
fordeverpower
i forgot to mention but if you go to time you engine. Disconnect the spout conector first. Its like a computer chip and is located near the distributor it just unplugs and be careful not to lose it cause its small and black.
SeaCarr
Mar 1, 2017 07:49 AM
rpaxton939
17
Mar 7, 2016 10:55 PM
BrokeGunner
45
Mar 20, 2014 08:28 PM
Rusty_Old_F250
54
Dec 30, 2010 11:28 PM
bronocIInoob
Bronco II
Dec 16, 2005 09:31 PM
