outside temp reading wrong
Old Jan 1, 2004 | 10:07 AM
hfeltrop's Avatar
hfeltrop
I have a 2000 Excursion limited v10. The overhead console with the outside temp, mpg, and compass works fine except the temp reading is wrong-- sometimes by 10-12 degrees, sometimes by 20-30 degrees. It seems to want to hover around 60-65
degrees (F). Any ideas how to fix? Where is the outside temp sensor located ? Thanx
Old Jan 1, 2004 | 02:43 PM
Monsta's Avatar
Monsta
Sit. Stay.
The sensor is located behind the front grill. It is the thing on the driver's side. You can see it by looking through the grill. It is about 3-4 inches high, cylindrical and kinda almost pointy on top. Anyway...it is easily replaced.
A computer reset may help. Just unhook your battery for 15 minutes.
Old May 6, 2004 | 03:04 PM
ffmbiggs's Avatar
ffmbiggs
hey hfletrop did you ever find a fix to your outside temp senson. I have a 2000 F-150 with the same problem. Thanks
Old May 6, 2004 | 06:21 PM
hfeltrop's Avatar
hfeltrop
No, I havent. It seems that when the real cold snap ended, it started to work fine. Have not had any trouble with it since
