Clicking noise from the rear diff
Old Dec 31, 2003 | 10:24 PM
underDAWG's Avatar
underDAWG
I replaced my drums today. While I have the drum off I turned my axle. I heard clicking sound coming from the diff as I turn the axle. However, when I put the drum on, the clicking is gone Do you guys it is the carrier bearing? Where should I check for trouble. TIA.
Later,
Old Jan 1, 2004 | 07:58 AM
RTM's Avatar
RTM
Not sure what you heard? Did you have the drive shaft hooked up when you turned the axle?
If you have a bad bearing there should be some play in it.
Old Jan 1, 2004 | 09:23 AM
underDAWG's Avatar
underDAWG
I did not disconnect the rear DS, but when I turned the axle shaft the DS was not turning. The clicking noise is definattely coming form the diff general area, but hard to pinpoint where. One more interesting observation: when I took the diff cover off, the oil was blueish tint color, but no metal shaving. Any thought on this. TIA.
Later,
Old Jan 1, 2004 | 09:28 AM
RTM's Avatar
RTM
Other than a visual inspection I don't know what to say. I've never incounter a noise like you speak of. Was the other drum on at the time of the noise? Maybe something in the brakes on that side? I am sure I am reaching now.
Old Jan 1, 2004 | 09:52 AM
underDAWG's Avatar
underDAWG
The noise only exists when there is no drum or wheel attached to the axle. I suspect that only when there is NO downward force on the out axle, clicking noise can be heard. Any thought on this? TIA.
EDIT: both drum were off.
Later,
Old Jan 1, 2004 | 11:29 AM
RTM's Avatar
RTM
Is this an 8.8 or a 9 inch rear? The 8.8 have some movement to them from the clip that holds them in. Maybe thats all it is.
