new ignition advice
Old Dec 31, 2003 | 02:31 PM
bigdumbtruck's Avatar
bigdumbtruck
new ignition advice
I'm swapping my tired 400 for a 351W and I'll need a new Distibutor/ignition system. I'm looking for better MPG and dependabilty. Any advice to get me going? '81 F250 4X4
Old Dec 31, 2003 | 03:29 PM
joners's Avatar
joners
When I got my 351W I was told to ask for ignition system from an '85 Bronco, DuraSpark II ignition.
Old Jan 1, 2004 | 06:58 AM
jwtaylor's Avatar
jwtaylor
I would do what Joners recommended or go ahead and get an msd distributor/ coil/ ignition box. later
Old Jan 1, 2004 | 06:03 PM
bigdumbtruck
The two system I've been looking at are the DUI from Centech and Jacobs. Any word about those, good or bad?
Old Jan 1, 2004 | 07:58 PM
jwtaylor's Avatar
jwtaylor
I have heard the dui is a good piece, who can argue with a clean engine compartment (no additional ignition box or coil scattered around) and one wire hook up. There have been a few people on here that have went with the dui or a similar unit. The jacobs is fine as well from what I have heard, kinda pricey though. I have only had experience with the duraspark II and msd and like them both. later
Old Jan 2, 2004 | 04:43 AM
clean79150's Avatar
clean79150
I went with a GM style distributor with the coil in the cap, and one wire hook up, I can't think of the name of it, but it was around $200.00, and it works fine.
Old Jan 2, 2004 | 09:57 AM
daerhldgs2's Avatar
daerhldgs2
try Davis Unified ignition , reasonably priced and works great.
Old Jan 2, 2004 | 11:16 AM
RTM's Avatar
RTM
I would second the DuraSpark II ignition. It's cheap and very dependable. I can't say that the others may out perform the ford set up but I bet the ford set up will out last all of the others. If you break down, you can get a replacement part any where if you have the DuraSpark II ignition set up.
The total cost would be around $50 for a new dizzy plus a core and $20 for the module. I run this same set up on my 400hp 65 mustang and had the same set up on a 70 mustang with a 460SCJ motor with 550hp. The 460 ran great until I ran it at 8K once to many times. Man that was a big smoke screen when it let go.
Old Jan 2, 2004 | 06:20 PM
daerhldgs2's Avatar
daerhldgs2
try the duraspark and a gm hei module --works great and only one wire
Old Jan 2, 2004 | 08:24 PM
fordeverpower's Avatar
fordeverpower
i would also stay with one of the durasparks or go get msd dizzy and box.
Old Jan 8, 2004 | 11:53 PM
bigdumbtruck
Thanks for all the info, I ended up getting my 400 rebuilt and switched from a 2b to a 4b which means a new carb. Now my pocket book hurts so the update on the ignition system will wait. I'll share my experience when I'm done.
