nasty backfire
Old Dec 31, 2003 | 02:25 PM
88treadbrite_150_4spd's Avatar
Question nasty backfire
here is what i did i took the 300 out of my 88 f150 and put in a 1990 5.8l and after getting it started it has a bad backfire out the rightside at idle and a loud popping backfire out the leftside when on the throttle. the only thing not hooked up is the oxygen sensor. it also lopes like i put put a cam in it but i didn't it don't think it has cam and i don't think it is out of time but i havenot checked.
any help would be greatly appreciated
Old Dec 31, 2003 | 03:40 PM
EPNCSU2006's Avatar
EPNCSU2006
Check the firing order, timing, and rotor phasing. Get the O2 sensor hooked up soon as you can as well. Also make sure the EGR is not stuck open.
Old Jan 1, 2004 | 12:51 PM
everything checked out ok but it now does not even run on all 8 so is there anything else that could be bad or wrong possibly the coil or somthing i,m at a loss on this thing
Old Jan 1, 2004 | 02:06 PM
please read and post any help
would i have to change anything electronic like the comoputer or get a chip to run the 5.8 because i havent done anything at all like that.
the 88 f150300 had differnt wires than the 5.8 which had four round plugs white black brown and grey. so i checked my 89 f150 parts truck that had a 300 in it and it had the same plugs as the 5.8 so i changed the harness from the firewall to the battery and from the firewall to the tailights. any thing else i need to do to the wiring. i had the the motor running but never to good not on all 8. does the computer need to be reprogrammed if so how do i do that.
i really need to get this truck running it is all i have to drive.
please help
Old Jan 1, 2004 | 04:44 PM
EPNCSU2006's Avatar
EPNCSU2006
Are you running the computer from the 300? If you are, then that is your problem. Get a computer for a 351 and one that is for the transmission in your truck.
Old Jan 1, 2004 | 05:05 PM
Slade901's Avatar
Slade901
I agree with EPNCSU2006. Everytime you swap a different engine, you must swap the computer as well.
Old Jan 1, 2004 | 06:10 PM
mjb1962's Avatar
mjb1962
I would think you would need the computer for the 5.8.
Mark
Old Jan 1, 2004 | 06:13 PM
mjb1962's Avatar
mjb1962
Also, is the wiring harness wired the same between the computer and the engine on the 2 different engines?
Mark
Old Jan 1, 2004 | 06:23 PM
EPNCSU2006's Avatar
EPNCSU2006
^ Good point. Check a wiring diagram to see what all is different in the harness. The injector harness is definitely different, other stuff should be very similar.
Old Jan 1, 2004 | 11:45 PM
thank you i will try to find a computer for it.
will the computer out of 1995 f150 5.8 work or do i need one from an 87-92 f150?
it is a 4spd manual trans does that mean id need a computer for the 5.8 with a 4 spd manual trans also or will one fom an automatic work for me?
Old Jan 2, 2004 | 08:16 AM
mjb1962's Avatar
mjb1962
I am not an expert on swaps but I would think the computer's timing and fuel mapping would be different on an auto vs. manual. Also the 95 computer for an auto would be looking for the E4OD I believe. The auto computer would have outputs for the torque converter clutch, shift solenoids, etc. It may have inputs sensing transmission status. I would find one from a vehicle with the same transmission and engine, same year if possible. Get the harnesses between the computer and engine/transmission while your at it.
Mark
Old Jan 2, 2004 | 04:30 PM
EPNCSU2006's Avatar
EPNCSU2006
It needs to be for a manual transmission.
Old Jan 12, 2004 | 08:35 PM
i got the computer from napa for $112. now the truck runs good no misses or anthing. but it has no power it will not accelerate at all (slower than 55mph in a 1/4 mile) it will not burn the tires at all. shouldn't a regular cab short box 351 4 spd with a k&n replacment filter and pace setter shorty headers with 3 inch cat back dual exhaust be able to break the tires loose on wet blacktop. do i need a chip because of the exhaust and the headers.
please reply i need any help i can get thank you
Old Jan 12, 2004 | 10:14 PM
i really want get my truck up and runing it just has not been good with out it
