speed density vs mass air
Old Dec 31, 2003 | 01:52 PM
frdcowboy's Avatar
frdcowboy
wondering what the difference is between a speed density system and a mass air system. How do they each work? Also which one is better and more reliable?
Old Dec 31, 2003 | 02:15 PM
EPNCSU2006's Avatar
EPNCSU2006
The main difference is in how the computer determines the amount of air entering the engine. A speed density computer infers the amount of air based on the air temperature, throttle position and manifold vacuum. A mass air computer uses a mass air meter to directly determine the mass of the air entering the engine. The computer uses the barometric air pressure sensor and air temperature to fine tune what the mass air meter senses.
Neither one is more reliable than the other. The most common ones are all EEC-IV, mass air and speed density. The mass air computer is better at adapting to modifications that change the airflow characteristics of the engine. In general, mass air computers also fire the injectors sequentially (truck computers, cars had sequential speed density computers) instead of batch fire, where four injectors are fired simultaneously.
Old Dec 31, 2003 | 05:09 PM
frdcowboy's Avatar
frdcowboy
so would u reccomend gettin one with speed density or mass air? could i still upgrade the air intake or air filter.
Old Dec 31, 2003 | 05:23 PM
StrangeRanger's Avatar
StrangeRanger
Unless you go with a radical change to the camshaft or swap for a set of full-race ported heads, it's pretty likely that the S/D system won't care. There is no simple bolt-on mod that will upset S/D. The best of all possible worlds is a 95 truck with MAF and OBD-I
Old Dec 31, 2003 | 07:36 PM
95 F150's Avatar
95 F150
I like my 95 model with mass air, didn't realize how lucky I was to have it when i bought it
Old Jan 1, 2004 | 09:11 AM
fastback69's Avatar
fastback69
Here is a site with good EFI information http://fordfuelinjection.com/index.htm
