Help
Old Nov 16, 2003 | 05:21 PM
WALJON's Avatar
WALJON
Help
CAN YOU HELP!!! 91 F 250 had 351W put rebuilt 351W from 73 galaxy lotsa mesin around its in runs no oil pressure IS THERE A DIF. IN OIL PUMP SHAFTS????? I put all EFI parts back on.
Old Dec 31, 2003 | 11:29 PM
87 xlt lariat's Avatar
87 xlt lariat
should not be any difference in shafts.if oil pump was taken out or taken apart it may have lost it's prime. causing an air pocket in pump. as a result low or no oil pressure.
Old Jan 1, 2004 | 07:56 AM
RTM's Avatar
RTM
Are you getting oil at the rocker arms?
Old Jan 1, 2004 | 08:11 AM
Slade901's Avatar
Slade901
Do you hear a knocking noise?
If you don't hear a knocking noise then it could be just the oil pressure switch or the oil pressure gauge not working.
Get an electric type oil pressure gauge (it's easier than the mechnical because you are not using that tiny hose that might break). If the electric type oil pressure gauge shows fairly good pressure then it is just your oil sensor or your oil sensor gauge.
Old Jan 1, 2004 | 09:12 AM
WALJON's Avatar
WALJON
THANKS but figured out it has lotsa press. just the senser in the block dorked
