electric door locks problem
Old Dec 31, 2003 | 12:45 PM
fred e's Avatar
fred e
I have a 1990 four door f-350. My 2 front doors lock properly but the 2 back doors will not lock or unlock. When I try to manualy lock or unlock them they are stuck and will not move the mechanism. I removed the door panel but still no luck. Any help would be appreciated.
Old Jan 1, 2004 | 05:25 PM
001-F DORF's Avatar
001-F DORF
I had the same problem on my 350 and just removed the lock motors. The motors get water in them and seize so you can't lock or unlock the doors. I find that it's no problem without rear power locks.
Old Jan 1, 2004 | 06:16 PM
fred e's Avatar
fred e
electic door locks problem
How much trouble is it to remove the lock motor? Where is it located? Thanks
Old Jan 1, 2004 | 07:00 PM
richierich45's Avatar
richierich45
check out the tech tips. someone wrote detailed directions on how to do it. My rear passenger side door is stuck and hard to move. my rear drivers side door goes up and down okay but the wire is broke between the door and the body. something i will fix when i get a round tuit.
SturgeonHunter
Jan 6, 2014 02:41 PM
khetlage
May 11, 2013 09:58 PM
jjs2032
Apr 22, 2008 08:27 AM
AustinAG01
1997 - 2003 F150
Jun 29, 2007 08:47 AM
