Help
Old Dec 31, 2003 | 08:20 AM
Rob`s55f250's Avatar
Rob`s55f250
Help
I`m new to this I`m trying to find parts for a 55 f250 the fenders & running boards, bed have some dents & rust I thought if i could find some New stock metal parts I could replace them. I have seen for f100 but i am told they are different. Could you point me in the right dirrection thanks.... Rob
Old Dec 31, 2003 | 08:34 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Rob,
The bigger trucks have been largely ignored by the aftermarket, so finding parts won't be easy. I'm converting my F-3 to an F-1 for just that reason. Some parts from the F-100s will fit your F-250, but for the most part you will have to scrounge the swap meets and classifieds for used parts. Will it be an original truck or modified? Good luck either way...
Old Dec 31, 2003 | 10:36 AM
Rob`s55f250
I`m trying to stay original but since it no longer has the original engine it is still a 6c though, I will make some modifications.
Old Dec 31, 2003 | 10:42 AM
cheinz46's Avatar
cheinz46
Check the e-bay auctions every day for the items you need. I'm sure they will pop up some day.
Old Jan 1, 2004 | 12:09 AM
cheinz46's Avatar
cheinz46
Rob, I am looking at my National Parts Depot (NPD) catalog. They sell replacement fenders, front & back (flareside) for your model truck. The fenders are listed as interchangable for F-100 thru F350. Running boards for flareside are also listed as interchangeable for F-100 - F-350.
Old Jan 1, 2004 | 10:01 AM
GreatNorthWoods
Must be a misprint. Fenders might interchange even though the wheel well opening is larger on the F-250 and larger trucks, but there's no way the running boards are the same because the wheelbases and beds are longer on the bigger trucks...
Old Jan 1, 2004 | 11:15 AM
Rob`s55f250
I called (NPD) & spoke to "Logan" he was not sure & said call back tomorrow. but everyone else i have spoken to said they do not fit. I`ll see what they say tomorrow. everyone thanks for the info & help......Rob
Old Jan 1, 2004 | 11:38 AM
cheinz46's Avatar
cheinz46
Let us know what they saw about the parts.
