Sponsored by: Real Truck
SD Brakes ( why do they feel weak?)
Old Aug 19, 2002 | 09:03 PM
daimon1054's Avatar
daimon1054
Old Sep 11, 2002 | 08:00 PM
S Casey's Avatar
S Casey
Had my 250 SD supercab V10 a couple of weeks now.
Besides the crappy tires (Firestone Steeltex that I hated so much I replaced them) and a wandering problem ( that went away after a few miles and the tire swap) my biggest complaint is that the initial brake feel is weak.
When I jump in my 94 150 SC and hit the brakes they just about lock up as I am pressing them like the 250 SD. The 250 brakes take way more effort to get the thing slowed down. This seems weird to me cause the 250 has 4 wheel disk and the 150 has rear drums and front disk. I know that the truck is bigger and heavier but with brakes sized for towing I would think that they would function better. They feel fine once I get into them but initial bite sucks.
Are they like this or is there something I can do to improve initial bite and feel?
Old Sep 11, 2002 | 09:14 PM
Outpost22's Avatar
Outpost22
[updated:LAST EDITED ON 11-Sep-02 AT 10:15 PM (EST)]You can put high performance pads on, but you gotta remember that these trucks weigh (depending on configuration) about 6800 pounds. They're NOT F150's;-)
You might also check to make sure your brakes are bled. Go to a dealers and drive another one and see if they stop the same. This might indicate if yours are "A-ok".
Geez, I just realized post #300. I gotta get a life
Old Sep 12, 2002 | 08:44 AM
Monsta's Avatar
Monsta
Sit. Stay.
Tell me about it!
Old Sep 12, 2002 | 05:22 PM
4x4x4x4's Avatar
4x4x4x4
Everything on these trucks is heavier than on a half ton and IMO the wheels and tires have quite a bit of inertia to overcome when stopping.Having said this you may never get that half ton brake feel with factory parts.
Here are a couple of things that can reduce braking performance.Are your brakes broke in?Braking performance is usually not up to snuff the first 500mi.or so.Breaking in brake pads too hard can also reduce braking performance over the life of the pads.
Old Sep 12, 2002 | 11:07 PM
S Casey's Avatar
S Casey
4X i figgerd that.
I'm hoping they just need to bed in.
I've run in a pad or two though and I think this thing is going to feel weak on initial bite anyway.
Old Sep 12, 2002 | 11:18 PM
FortyFords's Avatar
FortyFords
only other thing you might have them chk is a vacuum leak to the brake booster.
Rich
Old Sep 13, 2002 | 09:56 AM
79CEEJAY's Avatar
79CEEJAY
S Casey, if everything else mechanical seems okay, try the high performance pads. I had......carbon metallic pads on my F-150. They stopped much, much, much quicker......they also chomped the rotors much, much, much quicker. I know there are many brake upgrades out there, so do your homework first. How 'bout vented rotors? Are there any out there for the Ex's and S/D's???? Just curious?
Old Sep 13, 2002 | 07:36 PM
S Casey's Avatar
S Casey
CJ I'm checking to see if Performance Friction makes pads for the SD.
If so I'll give em a try.
Old Sep 13, 2002 | 07:51 PM
Monsta's Avatar
Monsta
Sit. Stay.
www.AppliedRotorTechnolgy.com also makes Rotors and pads for the Super Duty. I'll be putting a set on my Excursion within the next few weeks.
Old Oct 11, 2002 | 01:55 PM
S Casey's Avatar
S Casey
Just and update for those interested.
After 1100 miles and a trip to the dealer whose brake expert told me they weren't as good as the could be but would be better after 2000 miles(insert idiot icon here). I decided I couldn't live with wooden brakes on my new ride. I put Bendex Fleet MetLok pads on the front and am now a happy camper. They have superior cold performance, much better initial bite and modulate much better with way less pressure. Not a bad upgrade for $125.00 installed.
What pisses me off is that on a truck with a sticker over $32K I had to #####can the Firestone ATs and the front pads just so my truck works like it should. Doesn’t anyone at Ford drive these dang things? Or maybe the test drivers like trucks that wiggle all over the place and don’t stop.
Old Oct 11, 2002 | 06:52 PM
kjw84fxr's Avatar
kjw84fxr
I had or have the same problem with mine as well. After several trips to several dealers they say they are just fine, so i just stand harder on them, it is still under warranty so if it breaks they fix it.
Old Oct 12, 2002 | 10:43 AM
S Casey's Avatar
S Casey
So if you hit someone or something do they fix that?
Old Oct 14, 2002 | 11:34 AM
Shepard's Avatar
Shepard
There have been many posts with good information about the weak super duty brakes in other threads. When I complained about mine to the dealer they actually replaced the booster. They said they felt after testing the truck, that the booster was "weak". If it made any difference, it is so slight as to be almost unnoticeable.
Ken - When you get your a.r.t.'s done, please post and let us know how much of an improvement there is - Thanks
Old Oct 14, 2002 | 01:35 PM
plumr's Avatar
plumr
You guys can get mad if you want but the way I see it is FORD BRAKES STINK>>> They are weak. I don't care if the truck weighs 55,000 lbs weak is weak and they are weak So thats the way it is and you have to live with the weakness because FORD is never gonna change thats just the way they are... And when I say weak I mean when I tromp on the pedal and it fades out and never grabbs at all and sometimes scares the &**$&#^ out of me that is what I mean. Now you would think since FORD is a heavier built truck than the dodge and chevy they would also realize that they need just as heavy braking system, but thay don't and they won't because thats the way it is...now you all know how I feel about the brakes on my truck....
00 F-250 4+4 Ext. Cab Long Bed
