Oil light
Old Dec 30, 2003 | 07:09 AM
mrmoo's Avatar
mrmoo
Question Oil light
'78 F-150 2WD 351M C-6
Hey guys, do any of you know at what pressure the oil idiot light comes on? My light comes on when the engine is warmed up and idling in gear. (I know! worn bearings!) but if I rev it just a little it goes out so I'm hoping that maybe even though the light is on it's still in the safe zone. (I've heard some of you say as little as 5psi) I should connect a mechanical gauge, but I can't reach back there. So at what psi does it come on?
Old Dec 31, 2003 | 03:49 PM
macguyver's Avatar
macguyver
I think it's in the range of 3 to 8 psi. I know that's not much but there isn't a lot of load on the bearings at idle and even though the pressure isn't there, you're still getting oil flowing by those worn bearings. It's not a lot of protection but I've seen these engines go a long way with low oil pressure like that. Connect a mechanical gauge to make sure of what you've got. Using the rule of thumb that says 10 pounds of pressure for every 1000 RPM, if you're anywhere close to that, don't worry. Sometimes replacing the pressure sender will keep the light off.
Old Jan 1, 2004 | 06:57 PM
indyjames500's Avatar
indyjames500
I can relate directly with what your saying. I had that exact same problem with my 400 but the engine runs fine. So I replaced sending unit and the light quit coming on, for a while that is. Just tonight my light came back on lightly flickering while in gear at idle. So as soon as time and money permits, I'm going to schedule my engine for a teardown or replacement.
________________________________________
73 Ford Country Sedan station wagon 6.6L 400/V8, 103,000 actual miles.
