eletc choke converstion help!
Old Dec 30, 2003 | 12:17 AM
ddiede's Avatar
ddiede
Unhappy eletc choke converstion help!
I have a 70 f100 with 302 and i want to change the manual choke to eletc since all of the heat deflectors have broke off.
I bought the part but it come with the directions to install it.
It has 2 parts one is a square piece with four wirs coming out of it. and a brass clamp. I think it is to sense the heat. and the other part is the the choke coil that connects to the carb.
#1 where do i mount the square piece
#2 I know that two of the wires go to the choke coil and i assume that the other to are pos (red) and ground (White) where do i hook those up at?
Help
Dusty
Old Dec 30, 2003 | 05:14 AM
F100DREAM's Avatar
F100DREAM
Glad you asked that question because I have one also. I put my electric choke conversion on an edelbrock 600 cfm carb (1971 Sport Custom) and have no idea where to hook the hot wire up. It is not long enough to run anywhere except the ignition coil and the starter solenoid (ignition coil would be very bad, might fry the thing). So, if someone has done this on an edelbrock, please chime in? Thanks, Doc. I might just put this in the electrical section to, you think?
Old Dec 30, 2003 | 08:19 AM
F100DREAM's Avatar
F100DREAM
Ok, in the electrical forum, it is suggested that you connect the electric choke (hot I assume) to the alternator.
Old Dec 30, 2003 | 07:11 PM
Opiewan's Avatar
Opiewan
yeah should be the black connection on the alternator. thats the way i hooked up mine
Old Dec 30, 2003 | 09:39 PM
pat67shorty's Avatar
pat67shorty
Hook it to the stator termanal on the alt.
Old Dec 31, 2003 | 07:43 AM
F100DREAM's Avatar
F100DREAM
Pat, is the strator terminal the one with the blue wire? and i thougt you would hook the hot (red) wire to the alternator and the black wire to any grounded surface you could fine, thanks, doc.
Old Dec 31, 2003 | 12:25 PM
Opiewan's Avatar
Opiewan
mine is hooked to the negitive side, thats the only way mine works, maybe my truck is backwards
Old Dec 31, 2003 | 02:08 PM
Mike W's Avatar
Mike W
Use the stator term on the alternator. It is 7 volts. I put a Holley electric choke cap on a 2100; it fits. The Holley cap is a 12 volt unit. It just opens a little slower at 7 volts.
Old Dec 31, 2003 | 02:15 PM
BB's Avatar
BB
Mike, does it eventually open up all the way or did you have to tweak the index mark a couple notches?
Barry
Old Dec 31, 2003 | 04:35 PM
Mike W's Avatar
Mike W
It opened up all the way. I made a minor adjustment when I first put in on and it was fine. I just set it to where it was slightly open when cold.
