Master Cylinder Swap???
Old Dec 29, 2003 | 10:35 PM
biz4two's Avatar
biz4two
Quick question: Does anyone know of a way to swap out the typical leaky/rusty master cylinder from a '76 F-150 with power brakes?
I was thinking of using a new style with the twist on caps and see threw plastic. That way I eliminate both the leaks and rust...but still able to see the level without having to open the master cylinder. Maybe from a "newer" F-150 or F-250 from the mid-90's???
Thanks,
Old Dec 30, 2003 | 02:08 AM
Torque1st's Avatar
Torque1st
Posting Legend
You need to match bore and stroke for both front and rear sections. The mounting will be critical, you don't want that unit to fail during a panic stop. The proportioning valve may have to be changed also.
Maybe someone that has done it b4 will let you know.
Old Dec 30, 2003 | 08:59 AM
beartracks's Avatar
beartracks
I think I would just replace both pieces as a unit from NAPA. To prevent rust I painted the vacuum booster with epoxy black and the cylinder with black wrinkle. The wrincle paint is impervious to brake fluid.
Old Dec 30, 2003 | 05:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
Bear- Man where were you when I was asking about paints that would stand up to brake fluid for my upgrade.... -hehe
Old Dec 31, 2003 | 11:02 PM
biz4two's Avatar
biz4two
Are you talking about replacing as a unit with "original" parts? Or parts from a newer F-150/F-250?
Thanks!
shivaskeeper
Jan 10, 2014 04:06 PM
ynnad
Jul 26, 2013 04:52 PM
PWMTRUCK
15
Jun 30, 2013 01:37 PM
LARIAT 85
May 9, 2007 11:00 PM
Ford Truck Racer
Aug 27, 2005 09:29 PM
