Sponsored by: Real Truck
Weird noise... Need help
Old Dec 29, 2003 | 07:49 PM
Medic 13's Avatar
Medic 13
I have a very weird noise comming from my truck...
Turn off the radio, let the truck idle in drive or park, with your foot on the brakes or off and it kinda sounds like one of those cab over diesel box trucks ( kinda of a diesel noise ) speeds up a little as you accelerate but you loose the noise as the road noise increases, although I suspect it is still there.
Any one with any bright ideas???
P.S. I hate the antilock sensors I have now replaced both front ones.
Old Dec 29, 2003 | 10:17 PM
99f350sd's Avatar
99f350sd
what year and motor?
Old Dec 30, 2003 | 11:53 AM
Medic 13's Avatar
Medic 13
99 f250 SD v10
Old Dec 30, 2003 | 03:33 PM
99f350sd's Avatar
99f350sd
Exhaust leak..? bad idler bearing? Take belt off and spin pulleys.
buzzing pcv valve
Old Dec 30, 2003 | 04:42 PM
RedCrewCab4x4's Avatar
RedCrewCab4x4
99f350sd, Did you replace those ball joints yourself? If so can you give me some input on procedures? Thanks
RedCrewCab4x4
Old Dec 30, 2003 | 05:30 PM
99f350sd's Avatar
99f350sd
You got it
https://www.ford-trucks.com/contents...20Installation
Old Dec 30, 2003 | 05:48 PM
RedCrewCab4x4
Thanks for the help, 99F350sd
Old Dec 30, 2003 | 05:56 PM
99f350sd's Avatar
99f350sd
no problem ..use moog parts. I got mine from carquest w lifetime guar.. email me when you go to start I'll give you some pointers..
Dick
