Transfer Case Woes
Old Dec 29, 2003 | 04:25 PM
jfrank's Avatar
jfrank
Transfer Case Woes
I am having a little difficulty with the transfer case in my 95 Explorer Limited with control trac 4x4. It seems as if there is a little play in the shaft (I can move it up and down about 1/8 inch). It also leaks fluid out at the rear seal, and I imagine this is because of the play in the shaft, as I just replaced the seal when I replaced the speedo gear about 3 weeks ago. I am wondering if there is some kind of bearing inside the case that might be bad? If so, how do I go about replacing the bearing? One other question I have is I considered replacing the whole transfer case with a used one, but the ones they have for this year, the Borg Warner 1354, looks different than mine. Do the control tracs have a different model?
Old Dec 29, 2003 | 04:36 PM
mrshorty's Avatar
mrshorty
The 1354 is a part time transfer case that came on '91-'94 Explorers. It sounds like they haven't cross referenced correctly. I want to say that the Borg-Warner 44-05 t-case is the control trac t-case you're looking for, but that might be the AWD t-case for later V8's. Hopefully someone who knows the 2nd gen t-cases will chime in.
Not to say, that the 1354 won't work. I'm pretty sure that some have put it in. It's just different from the control trac t-case you have.
Old Dec 29, 2003 | 07:52 PM
Opera House Works's Avatar
Opera House Works
A beer can should fix it
And you think I'm joking! I had to fix my 4405 that had up-down rear shaft movement. I thought I had a bad bearing but the case is worn. They have a split housing for the bearing that is anodized to harden it. One end of mine was worn so I ground down the ridge and used some aluminum can as shim material. It won't last forever, but at least the aluminum shim will chew up easily. You might want to live with it. The rear seal is easy to replace and that might keep you going.
Old Dec 30, 2003 | 08:25 AM
jackiedc7's Avatar
jackiedc7
dearopera house works
please don,t try t sell me one of your vehicals
mr1
Sep 10, 2016 10:38 PM
dpilot83
Dec 23, 2015 09:43 AM
Zwalters
Dec 5, 2015 09:47 PM
chspyder
13
Sep 30, 2009 05:33 PM
TEEJAY
1997 - 2003 F150
Sep 9, 2003 08:38 PM
