Oil leaks
Old Dec 29, 2003 | 02:32 PM
2001yellowEdge's Avatar
2001yellowEdge
Oil leaks
my truck only has 18,000 miles on it, yet I've had oil leaks like crazy. The first time, it was spraying tranny fluid all over the exhaust, and I had to have a new tail shaft seal put on the transmission. It kept doing it, so then I had to have a new driveshaft put in, as well as a new tail shaft seal. Now there is engine oil leaking on my garage floor, and it is dripping right off the bottom of the bell housing. It looks like its coming from the rear main engine seal. I don't know if this one is going to be covered under warranty, as my truck is an 01'. Has anyone had these problems, and how much was it to fix? Im pretty mad right now, seeing as how a truck that only has 18,000 miles on it should NOT be leaking oil.
Old Dec 29, 2003 | 05:17 PM
el conquistador's Avatar
el conquistador
for starters call the dealer and find out if it is covered under the warranty
