acceleration issue
Old Dec 29, 2003 | 01:29 PM
Bronco86's Avatar
Bronco86
acceleration issue
i have a 86 bronco 302efi, fun pretty good around town, and highway as long as i don't give it too much gas....if i say try to pass some one it will bogg out and intermittently stall. even if at a dead stop i try to punch it same thing.....newer pumps / filter, what could it be? what should i check? please help
Old Dec 29, 2003 | 04:25 PM
f100guy's Avatar
f100guy
check the ignition module and coil
Old Dec 29, 2003 | 05:05 PM
Bronco86's Avatar
Bronco86
would that cause this prob? it starts great and runs good till i give it alot of pedal
Old Dec 29, 2003 | 07:04 PM
Blly177's Avatar
Blly177
check your fuel pressure regulator but your tps may be going out
Old Dec 30, 2003 | 10:07 AM
Bronco86's Avatar
Bronco86
ok i just whent out and bought a fuel pressure gauge......what is the best way to test?
Old Dec 30, 2003 | 02:08 PM
LxMan1's Avatar
LxMan1
The converters aren't clogging up are they? Restricting the exhaust?
Check your timing too. The chain could have jumped a tooth. This would cause it to run ok at part throttle, but not under heavy throttle.
Jimmy
Old Dec 30, 2003 | 02:15 PM
Bronco86's Avatar
Bronco86
i haven't checked that thanx
no i don't think the cat's are clogged
the only prob i have found so far is my loud a$$ fuel pump
Old Jan 2, 2004 | 11:38 AM
Bronco86's Avatar
Bronco86
ok i am getting good pressure, tps is working, and i replaced fuel filter........prob seemed to go away when i drove around the block (acceleration was good). but when i drove latter the acceleration was back to crappy......both fuel pumps are working fine....what now????
Old Jan 6, 2004 | 12:43 PM
EastTexF250's Avatar
EastTexF250
Acceleration isue
I am having the same issue with my 99 v10 f250. new filter. new air filter. I dont want to replace the fuelpump if i dont need to. The computer my shop put on it says fuel circut #2 is low and EGR bad. Any ideas????
Old Jan 6, 2004 | 12:48 PM
Bronco86's Avatar
Bronco86
replace egr, test fuel pressure
blakdymond
Jan 3, 2017 09:52 PM
Hardcase_Ford
Bronco II
Nov 16, 2008 07:49 PM
81caprigt
1978 - 1996 Big Bronco
Jun 20, 2003 03:11 PM
AbadDriver
Bronco II
Jul 19, 2002 12:08 AM
markt
Aug 10, 2000 09:57 AM
