Air Bag indicator blinking codes?
Old Dec 29, 2003 | 10:24 AM
kdewise's Avatar
kdewise
My airbag indicator has been blinking for some time now. It's a pattern is 3 blinks pause and then 2 blinks. It repeats ad finitum.
Where can I find the code descriptions?
Thanks.
Old Dec 29, 2003 | 01:07 PM
Burg460's Avatar
Burg460
A code 32 is a bad clock spring. Do a search for code 32 or bad clock spring and you will get alot of results. A new clock spring is about $100 at a Ford dealership just for the part.
Old Dec 29, 2003 | 02:05 PM
DanZ's Avatar
DanZ
Some of the cheaper manuals (Haynes, Chilton, etc) could have them but I know the factory manual does.
My Mustang has a blinking airbag light and my Ford manual says which component is bad and how to troubleshoot/fix it.
I HIGHLY recommend getting access to a factory manual because airbags can be dangerous and expensive if you do the wrong thing. The Ford manual will tell you how to deactivate the system and when to do it. Some fixes are easy but others are listed with many tests that should be done in a specific order. Don't just replace stuff, wire and connectors can be the culprit.
So for an airbag light don't just replace components until you have checked everything in that circuit, and above all BE CAREFUL.
I'm sure someone on this site has a factory manual but make sure you get the whole test procedure for your number of flashes and also get all of the deactivation infor.
Bronco Billy
1983 - 2012 Ranger & B-Series
Dec 25, 2014 03:33 PM
F150vettehauler
2004 - 2008 F150
Jun 21, 2014 06:31 PM
Pequeaford
Jan 28, 2014 09:11 PM
WalleyeHunter
Dec 16, 2004 10:15 AM
bmwfirearms
16
Oct 15, 2004 02:43 AM
