rear main leak
Old Dec 28, 2003 | 10:56 PM
whall's Avatar
whall
rear main leak
i recently bought a 79 bronco w/400, i know little about these motors as i have only had experience on smaller ford motors particularly 351w. I was out muddin the other day and burried the front end, by the time i had to leave the bronco there over night and came back the next day to fish it out. the motor wasnt under water but on the way out of the trail i blew the rear main seal. i already got the pan off and i am in the process of changing the seal. the oil was a little thick and there was a little bit of water in it. is there anything that i can check while i am down there working to clue me in as to whether i damaged anything besides the rear journal without taking things to far apart? The motor started to knock when the seal went and i heard it knocking but shut it down quickly. All of the surfaces on the bottom end of the motor are still coated with oil so i know that they didnt get hot enough to burn it off. Thanks for any help.
