Thermostat housing question
Old Dec 28, 2003 | 09:35 PM
79blueoval's Avatar
79blueoval
On my 79 F-350 with a 400 on the thermostat housing there are 2 different pieces screwed into the housing that look like some kind of sensor but have nothing hooked to them, any ideas. If I failed to give enough info please let me know.
Thanks.
Mike.
Old Dec 29, 2003 | 12:01 AM
daveee's Avatar
daveee
One of them is a vacuum hose switch that goes to an amplifier and then on to the EGR valve. It makes sure the EGR valve only operates when the water temp is over 160 degrees
Old Dec 29, 2003 | 01:33 AM
bubbaf250's Avatar
bubbaf250
The other is a temp-sensing vacuum switch that switches the distributor vacuum advance between the spark port (for normal operation) and manifold vacuum (for faster idle when the engine is hot).
