What size engine do we have
Old Dec 28, 2003 | 08:15 PM
Kurts74ford's Avatar
Kurts74ford
I have an engine that you can only turn about 1/8 stroke with a wrench. the tranny is still hooked up and I believe that that is what is hanging it up. Any way. we are trying to figure out what it is. cant see the # on the crank. Only can see the # on the connecting rods. this is not a crossbolted blck. but if I read the connecting rods correctly, it should be a 427. the connecting rods are c3ae. what do i have
Old Dec 28, 2003 | 08:40 PM
fordman428's Avatar
fordman428
c3ae doesnt mean its a 427, it was made in 63 for a car is all that means, what is the block casting #'s, thats more helpful but to know for sure you would have to measure the stroke.
Old Dec 29, 2003 | 06:30 AM
Kurts74ford
Well we tried to figure the stroke out, but like I said, the engine wont turn a full stroke. I think that the old FMX that is bolted to it is holding it up. I will have to split the two apart and then try. KURT
Old Dec 29, 2003 | 10:41 AM
baddad457's Avatar
baddad457
C3AE rods were common to 390, 406 and 427's. You've most likely got a 390. Pull all the spark plugs and pour in a quart of ATF into all the cylinders. then try to rotate the crank.
Old Dec 31, 2003 | 06:52 AM
travs66's Avatar
travs66
Kurt,
Where is the #1 piston located? If you can get it to tdc then you can measure the difference in stroke using the #1 and #4 cylinders without having to turn it completely over.
Old Dec 31, 2003 | 08:16 AM
Kurts74ford
We tried that. you would think iit would work, but it didnt.
Old Dec 31, 2003 | 08:37 AM
travs66's Avatar
travs66
Could you not get #1 to tdc? What about getting #4 to tdc or using the #5 and #8 cylinders? Just trying to throw out ideas.
Old Dec 31, 2003 | 09:31 AM
Kurts74ford
No. The engine is at Clints. Kaylle and I think that the transmission is holding it up. It is an automatic. It isnt that important, just was curious as to what it was.
Old Dec 31, 2003 | 10:24 AM
Mike G's Avatar
Mike G
If you can see the crank casting number, that will tell what is in there. The number one piston is the "front-driver-side" and the number four is "rear-driver-side".
I do not understand the problem with the tranny you are having. Have you tried to disconnect the linkage and/or put the trans in Neutral? If that doesn't work, your engine may be seized, or the starter, if attached may be bound....
Just a few thoughts, --Mike
Old Dec 31, 2003 | 10:54 AM
Kurts74ford
First off, if you know anything about the FE engine family, you would know that the #1 psiton is on the Passenger side front of the engine and that #4 is at the rear on that same side.
The tranny has been put in Neutral several times and it still doesnt allow the engine to roll a full stroke. The engine (pistons and crank) are not seized. Though the valves may be stuck causing a problem. There is no starter.
Old Dec 31, 2003 | 12:12 PM
fordeverpower's Avatar
fordeverpower
I sure thats what he meant or he was drinking to many beers. We all know the number cylinder in on the passenger side. And in the cab its on the right bank so i am not sure what was up with him but he usually knows what he is talking about. I think!
Old Dec 31, 2003 | 01:16 PM
BB's Avatar
BB
He’s from Australia, mate!
Old Dec 31, 2003 | 01:21 PM
Kurts74ford
Well I hope that he ment that.
Old Dec 31, 2003 | 02:18 PM
Mike G's Avatar
Mike G
LOL---Sorry guys, too much cold medicine
Sounds like something has dropped into a cylinder stopping your rotating assembly (maybe a valve). Pull the heads off and see what you come up with from there.
--Mike
Old Dec 31, 2003 | 03:11 PM
Mike G's Avatar
Mike G
now I remember what I was thinking... Last time I was doing some quick cylinder numbering, the motor was on the engine stand turned upside down (wow, a bright flash of clear-headedness).
Carry on....--Mike
